no monitor lines
Old   May 26, 2009, 03:52
Default no monitor lines
Tobias Krawuttke
Tobias is on a distinguished road
Hello!
During running CFX solver my hard disk was full. After deleting some files my calculations continued. Also the text in the solver is displayed. But the lines of monitor data are not being updated any more. Restarting the solver cannot fix the problem. I dont want to restart my calculations. So is there any way to fix it?
Thanks for any help...Tobias
Tobias is offline   Reply With Quote
Old   May 26, 2009, 05:23
Matthias Voß
mvoss is on a distinguished road
hi,
did you tried to setup a new solver run from a bak.-file or did you just setup a new solver monitoring from "run in progress"?
If i get you right, you want to watch certain values progress during the run.
If it is transient, you get the trend from the trn.-files.
neewbie
mvoss is offline   Reply With Quote
Old   May 26, 2009, 06:53
Tobias Krawuttke
yes i want to have a look at monitor values during the run. Now I restarted with initial values and the error is the same.
Perhaps i can delete the former monitor data.
Old   May 26, 2009, 07:27
Matthias Voß
hi,
normally, the monitoring is part of the res.-file. Do you get an error-message?
Old   May 26, 2009, 10:21
Tobias Krawuttke
I fixed the problem by starting with definition file and ''interpolating'' from the damaged results. now it seems to work because no monitor or out file data is transferred to the new monitor
