May 18, 2009, 03:07 |
Yet another NACA0012 Problem
Steven Halliday
Long time reader, first time poster.
I am required to investigate using CFD whether the height of our wind tunnel is enough so as not to effect the flow around a NACA0012 foil that resides within. We have results from experiments to get the desired Cl and Cd values based on a series of Cp readings. To begin with the geometry was created with a thin extruded duct and the aerofoil cut out. The issues started when it came to meshing it with CFX. Glenn Horrocks (Thanks for that information you sent) mentioned that it can be tricky to get inflation to continue to and round the trailing edge of the foil. The attached image shows it dying off as it approached the end. The inflation layer itself goes from a prism height a fraction of the estimated boundary layer in height to the size of the other tetra cells. There is also constant face spacing along the foil surface. Is there a way to get the inflation layers to continue round to the back? The set up is a normal speed inlet, a zero relative pressure outlet. Global initilization has zero cartesian velocity components and a zero relative static pressure. Also, in the results, I've created a polyline going along centre of the surface of the foil. Using this I'm plotting in a chart the pressure variance with distance. To get the Cp instead can I create a function or variable based on the pressure and use it as the chart variable? Thank you very much for your time. Regards, Steven |
May 18, 2009, 09:09 |
Jules Bell
Yes, you can do this.
Depending on wether or not you want to monitor this variable during the solver run, you have to specify this variable in CFX Pre before starting the solver run. In this case I believe you have to include this extra variable in the output list. This will make your solution file a bit larger, because the additional variable value will be stored for every grid point. Also you cannot monitor line plots during solver run, only scalar values. Therefore it will probably suffice to define this variable in CFX post for evaluation. You can simply create a new variable, define its value with a CEL expression and use it for evaluation on your line plot. It's pretty easym with the help of the manual you can probably figure it out in 5-10 minutes. Good luck, Jules |
May 18, 2009, 20:13 |
Rep Power: 143 |
A comment about your mesh. It looks like you have the airfoil as its own body. The inflation tool has problems at the trailing edge, that is why your inflation layers reduce to nothing at the trailing edge. I recommend you put a thin cut out the end of the airfoil, and do an inflation mesh both sides of it. This will allow you to do a full thickness inflation layer right to the end of the foil. If you are clever you can also make the cut follow the airfoil wake then you will get much better modelling of the airfoil wake as you will be modelling it with prism elements not big tets. Glenn Horrocks |
May 19, 2009, 10:36 |
#4 | |
Steven Halliday
So you suggest cutting the duct during the geometry stage? Won't that effect the flow? Or do I just not assign a boundary condition to it in the solver? |
May 19, 2009, 21:54 |
Rep Power: 143 |
Yes, cut the duct in the geometry stage. You want a surface for the mesher to make prism layers on. But in CFX-Pre you merge the mesh back together again (this is recommended) or use an interface to re-connect them (not recommended). Glenn Horrocks |
May 25, 2009, 03:48 |
#6 | ||
Steven Halliday
Do I need to create virtual topology during CFX mesh to merge the two surfaces back together again? I've looked through their help files and can't find a direct mention of merging two faces in CFX-Pre. I tried an interface between the two and an alternative but it also spat out an error: Quote:
May 25, 2009, 10:17 |
Matthias Voß
Rep Power: 20 |
May 25, 2009, 23:17 |
#8 | ||
Steven Halliday
Thanks for the tip neewbie, but after changing face spacing to edge spacing the number of mesh elements it stopped throwing up the error below but it doesn't impact on the cell resolution along the foil like it should. I change the edge spacing values but the cell size on the foil is only dpenedant on the minimum default face spacing size. Quote:
May 26, 2009, 01:28 |
Rep Power: 143 |
When meshing you should set it up as a 2D extrusion with 1 element thickness. In CFX you then define them as symmetry planes. Also look here: http://www.cfd-online.com/Wiki/Ansys..._simulation.3F Glenn Horrocks |
May 26, 2009, 02:13 |
#10 | |
Steven Halliday
At the moment the cut extending from the foil goes all the way to the outlet and slices it in half so I have two outlet regions. Last edited by s4097294; May 26, 2009 at 02:47. |
May 26, 2009, 19:05 |
#11 |
Rep Power: 143 |
Two outlets should be fine. Glenn Horrocks |
May 26, 2009, 20:01 |
#12 |
Steven Halliday
But what about the two cut faces? I've tried setting them as interfaces, as symetry, as walls and in every case the solvre fails. Either due to an error
right away or after a couple of iterations because air is flowing back in the outlet. You mentioned merging the faces or creating an interface, merging being the better option. How exactly does one merge the faces of the cut back together? |
May 27, 2009, 08:13 |
#13 |
Rep Power: 143 |
The two faces can be merged in CFX-Pre. Providing the nodes match wither side then if you delete any wall it automatically generates and use a tolerancing thing hopefully you can do it. I have not done this for years so hopefully it still can be done! If the nodes don't match or you can't figure how to do it then just use an interface. Backflow are the outlet does not generally cause a solver failure. It might give a warning that artificial walls have been created. If this is the case then you probably have to move your outlet boundary downstream to be out of the wake zone. If your simulation is doing this does this mean the foil is stalled? You may need a 3D simulation with a DES approach to get any accuracy in the stalled region. Glenn Horrocks |
May 27, 2009, 11:05 |
#14 | ||
Steven Halliday
As for using an interface, I keep getting this error. Quote:
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Incoherent problem table in hollow-fiber spinning | Gianni | FLUENT | 0 | April 5, 2008 10:33 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
