-   -   parallel computing (MPICH2 local) error massage (http://www.cfd-online.com/Forums/cfx/64917-parallel-computing-mpich2-local-error-massage.html)
ggxhyst May 28, 2009 11:39
I have this anoying massage everytime I run simulation in MPICH2 local parallel using batch file. With this error I can still run the simulation in parallel in most cases, but I think it might cause solver failure and I want to fix it. The number of error massage is the same as CPU used. For example, if I use 2 cpu in my parallel setting, the error massages will look like this:
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\112 428 registry key, error 5, Access denied.
Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\571 28 registry key, error 5, Access denied.
Can anyone help me on this? Thanks!
Tony
bharath May 28, 2009 21:13
hi,
i think this is rights problem with the user
ykresnin March 21, 2011 11:45
@ggxhyst Launch the program "as Admin" and the error should go away.
ashfak59200 July 20, 2011 16:39
Thanks
It worked for my case!
