Reynolds contour plotting in cfx-post
Old   June 2, 2009, 03:16
Default Reynolds contour plotting in cfx-post
SMN
mortazavi is on a distinguished road
hi:
i want to plot a contour plot for reynolds number in default domain in cfx-post...how can i do it???
best regards
mortazavi is offline   Reply With Quote
Old   June 2, 2009, 19:02
Define a function for Reynolds number, then it will appear as a variable you can do contours with. Have a look in the tutorials for how to do this.
Old   June 3, 2009, 00:49
SMN
hi Glenn Horrocks and thank you very much for all your helps:
the geometry is very complicated and i cant define any effective length in reynolds num.also the direction changes and i cant use parameters like y or z as diameter in CEL.
the tutorial is very simple and i cant use it.
Old   June 3, 2009, 07:34
Well if you can't define a length scale then how can you work out a Reynolds Number?
I am guessing you are looking for the surface Re number to look for turbulence transition or turbulent boundary layer growth along a surface. This would be tricky to visualise on an arbitrary geometry. If you are using the turbulence transition model I think one of the variables modelled is in effect the surface Re number, that might help. Otherwise you might be able to define a length scale using surface streamlines where you use the position along the streamline as your length scale. Just an idea, it would be tricky to get working.
Transient animation performance in CFX 5.5 POST Sjoerd Romkes CFX 8 February 5, 2013 14:53
Assign new variable in CFX Post Ben CFX 1 August 25, 2008 14:59
Vof contour plotting Shane FLUENT 1 October 8, 2006 04:57
Reynolds Stress Model in Fluent Vs CFX Tim FLUENT 0 December 6, 2005 22:03
Contour plotting Mark Russell Main CFD Forum 5 April 22, 2000 22:45
