Nasa profiles
Hi,all
NASA WIND PROFILES, WHICH TYPE OF CODE BETTER AIRFOILS |
Can you state your question more clearly? I have no idea what you are asking for. Glenn Horrocks |
Nasa airfoil
HI,
Actually i am analyzing wind turbine rotor,in that i want select better blade airfoils ,i have lot of airfoils data,in that which is the better one, which type of series (ex:1,2,3,4,5,6,7,8 series ). |
Hi Sivaramakrihnaia,
We've been studying wind turbine blades for some years (three), and there are not all the types that you asked. In fact, the profiles are NACA, and the 5 digit series is one that you could start working. Hope that helps, Best Regards, Paulo Rocha |
Hi again,
Sorry for the information. I would like to say 6-digit series. :o What methodology will you use to design the blade (chord and pitch angle?) Best Regards, Paulo Rocha |
Nasa 6 series
diameter of rotor:2m, chord size:0.3m number of blades:3 is it any profiles is there. if dont mind your mail ID should forward me,i will send mail. Thankyou very much. |
My e-mail address is paulo {at} posmec [dot] ufc [dot] br What do you plan to do with the simulation. Will you build the turbine ? Regards, Paulo |
