June 3, 2009, 04:54 |
Nasa profiles
Hi,all
NASA WIND PROFILES, WHICH TYPE OF CODE BETTER AIRFOILS
sivaramakrihnaiah |
June 3, 2009, 08:47 |
Rep Power: 143 |
Can you state your question more clearly? I have no idea what you are asking for. Glenn Horrocks |
June 4, 2009, 02:13 |
Nasa airfoil
HI,
Actually i am analyzing wind turbine rotor,in that i want select better blade airfoils ,i have lot of airfoils data,in that which is the better one, which type of series (ex:1,2,3,4,5,6,7,8 series ).
sivaramakrihnaiah |
June 4, 2009, 14:00 |
Paulo Alexandre Costa Rocha
Hi Sivaramakrihnaia,
We've been studying wind turbine blades for some years (three), and there are not all the types that you asked. In fact, the profiles are NACA, and the 5 digit series is one that you could start working. Hope that helps, Best Regards, Paulo Rocha |
June 5, 2009, 16:42 |
Hi again,
Sorry for the information. I would like to say 6-digit series. What methodology will you use to design the blade (chord and pitch angle?) Best Regards, Paulo Rocha |
June 6, 2009, 01:22 |
Nasa 6 series
diameter of rotor:2m, chord size:0.3m number of blades:3 is it any profiles is there. if dont mind your mail ID should forward me,i will send mail. Thankyou very much.
sivaramakrihnaiah |
June 7, 2009, 00:33 |
My e-mail address is paulo {at} posmec [dot] ufc [dot] br What do you plan to do with the simulation. Will you build the turbine ? Regards, Paulo |
NASA Format | Stone | CFX | 3 | August 11, 2021 03:16 |
Laminar wing profiles and drag | gregorv | OpenFOAM Running, Solving & CFD | 4 | December 4, 2007 14:25 |
Gas flow profiles in mixing tank | srinivas | FLUENT | 0 | November 8, 2006 05:52 |
Variable Names in Profiles | Jonas Larsson | FLUENT | 0 | April 18, 2001 07:59 |
component flow direction fieldnames for boundary profiles required. | Ricky Wong | FLUENT | 1 | May 12, 2000 11:36 |
