Particle solid specific heat variable with temperature
I'm modelling a particle solid flow falling inside an heat exchanger. I need to set a temperature dependant specific heat law for the material of solid particles. I wrote an expression and entered it in the material panel, but the solver gives an error!
Someone can help me? |
Seriously, if you want help you will need to be a _bit_ more specific. What type of error did you get?
This is the error the solver gives me
Details of error:- ---------------- Error detected by routine PEEKR CDANAM = TABSMIN/VALUE CRESLT = NONE +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine MEMERR | | | | | | | | | | |
it would help if you post all the out file if its spits out the error at the beginning.
