MFX analysis
Old   June 10, 2009, 07:59
Default MFX analysis
Ema
Tuffy
Ema is on a distinguished road
Hi everyone,
I must use MFX to couple ANSYS thermal-electric and CFX. I'm using V12.
What I have done is:
-created a simple geometry (two cilinders, one inside the other one. In the small one I fix the fluid and in the other one a certain voltage on the external surface)
-fixed BCs and loads using ANSYS thermal-electric and exported the .inp file
-tried to convert the .inp file in .cdb file using ANSYS APDL, but it results impossible...
Can you figure out where is the problem? What can I do?
Once that I obtain the .cdb file from the mechanical analysis I must do the same using CFX. But how can I have an .inp file for the fluid part?
Thanks in advance!!!!!!
Ema is offline   Reply With Quote
Old   June 10, 2009, 09:06
ckleanth's Avatar
George
ckleanth is on a distinguished road
hi ema.
based on what you said you wanted to do
Originally Posted by Ema View Post
...I need to simulate the behaviour of a structure that has joule heating and a fluid flow...
from your Import data history thread
I sugested to use CFX to do your fluid flow and elecromagnetics and as Glenn said use the standard FSI capabilities to do your mechanical simulation. I have used elecromagnetics in CFX but it does work.
Top 4 tips
1. Knowledge is everything and Ignorance is dangerous.
2. Understand your limitations and try to eliminate them.
3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window.
4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials
ckleanth is offline   Reply With Quote
Old   June 10, 2009, 09:15
Ema
Tuffy
thanks for your advices...
I will use CFX, the only problem now is create the surface that has to communicate between mechanical and cfx.
Do you know how can I do that?
Ema
Old   June 10, 2009, 09:21
ckleanth's Avatar
George
Ema
with version 12 I thought this would be straightforward with the new fancy dancing flow diagrams so no I haven't done this yet, got too many things to learn in CFX still but I'm sure someone can indicate you how to do this
Top 4 tips
Old   June 11, 2009, 08:17
Ema
Tuffy
thanks...
Finally I get it...
but I still dont have heat transfer, I dont know why!!!!!!
Old   June 11, 2009, 11:04
Ema
Tuffy
I want explain it better...
once that i fix voltage and temperature using the thermal-electric i save the file with the .inp extension; then, using CFX and the ansys multifield external solver coupling,
I can start with my simulation.
the problem is that, even if i have the voltage generation i dont have changes regarding the temperature when i look at the results.
Does someone know why???
FSI Transient Thermal Analysis Abduri CFX 1 January 1, 2017 22:54
Fan Boundary conditions with external analysis Rob FloEFD, FloWorks & FloTHERM 1 February 10, 2009 00:04
heat transfer analysis inside the closed roam san FLUENT 0 March 3, 2006 06:26
Questions on Analysis Controls and Runtime Control Arnab Siemens 1 October 26, 2004 09:47
Short Course: Computational Thermal Analysis Dean S. Schrage Main CFD Forum 11 September 27, 2000 17:46
