-   -   Initial field from res file by "node to node" reading (http://www.cfd-online.com/Forums/cfx/65468-initial-field-res-file-node-node-reading.html)
Nevel June 16, 2009 05:13
Hi all!
I want to read initial condition from res file to new grid (some walls slightly moved). Simple interpolation isn't good for me. It would be more correct if the data can be read by the "node to node" way.
Is it possible? Can you advise something?
Thanks for responses!
ghorrocks June 16, 2009 07:59
If you want node by node reading and setting of initial conditions then you need user fortran.
You may also be able to do it by exporting data from CFX-Post, then doing whatever transformation you like on them and then reading them back into CFX-Pre as a 3D cloud of points. This should work as long as your mesh is not too big.
