June 21, 2009, 05:58 |
ANSYS Multi-physics and CFX coupling error
Anujit
I will be grateful if some one helps me to debug this problem. We have recently installed ANSYS (V10.0). We are trying to run FSI problem by coupling ANSYS multi-physics and CFX. But the analysis comes out with the following error: ---------------------------------------------------------------------------- MULTIFIELD ANALYSIS BY SOCKET COUPLING: MASTER CODE SETUP SYNCHRONIZATION POINTS FOR DATA TRANSFER CREATE SOCKET CONNECTION Port number = 49800 Master Socket number = 1 Number of codes = 2 Slave ID: 2; Socket number = 2 FIRST SYNCHRONIZATION POINT OF MASTER CODE: GET CODE INFORMATION FROM SLAVE CODES *** WARNING *** CP = 5.500 TIME= 13:51:02 Error in get code VERSION through Socket 2 . ********************* MF_send_Error Msg: UNKNOWN IERR 0 *** FATAL *** CP = 5.500 TIME= 13:51:02 Error during get code info. UNKNOWN. ALL CURRENT ANSYS DATA WRITTEN TO FILE NAME= ansabort.db FOR POSSIBLE RESUME FROM THIS POINT ************************************************** ********************** The above error is non-recoverable by ANSYS ANSYS run terminated by the indicated error Current data base saved if possible. ************************************************** ********************** -------------------------------------------------------------------------------------------------------- END of ERROR message -------------------------------------------------------------------------------------------------- It will be of great help if someone can give me a solution. Please help me!!!! Thanks in advance... Anujit |
June 21, 2009, 07:50 |
Rep Power: 143 |
Can I ask why when you "recently installed" it you installed V10? That version is something like 3 years old. The current version (V12) has had many refinements of the FSI interface and it should run much better. Don't waste your time with old software. Glenn Horrocks |
June 21, 2009, 08:48 |
Anujit
Thanks for your reply. Our group is very new to this field. We are trying to explore this field. We got access to the setup file of ANSYS v10.0. I don't think we have V12.0 setup. In fact in my previous organization, V11.0 was installed only in Dec, 2008. Thanks and regards, Anujit |
June 21, 2009, 18:39 |
Rep Power: 143 |
I repeat my previous post - if you have recently got CFX then why did you install an old version? You should have got the current version so you should install that. My second point is that FSI is much improved in V12 so your problem will probably be resolved. Third, don't waste your time on old software. If your time has any value at all then it makes sense to use the current version. Glenn Horrocks |
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/cfx/65613-ansys-multi-physics-cfx-coupling-error.html
Posted By | For | Type | Date | |
?????-???????? : ansys coupling error mapping summary | This thread | Refback | October 26, 2013 01:34 |
Tube in Tube heat exchanger( But I got error) | Young | CFX | 2 | September 26, 2008 01:35 |
How to purchase ANSYS CFX? | Michael Skoblin | CFX | 1 | October 31, 2006 07:51 |
Error in CFX Solver - reg | Fredrick | CFX | 1 | March 5, 2005 01:41 |
