Tips on using mesh stiffness for mesh deformations |
February 21, 2005, 04:34 |
I am trying to analyse an aerofoil which is flapping up and down in CFX. I have managed to implement the mesh deformation in the simulation, however after a number of timesteps in the simulation the solver terminates with errors indicating a negative element volume in the mesh. Any suggestions on the proper use of setting the mesh stiffness to avoid this would be much appreciated as I kind seem to find much in the manuals regarding the use of proper units and numerical values.
Thanks in advance. |
February 21, 2005, 16:32 |
Re: Tips on using mesh stiffness for mesh deformat
Mesh stiffness only has an effect if it varies. That is if you set a constant value for the entire domain then all nodes are equally free to move. To make it have an effect you need to make it vary over the domain. As described in the documentation, two useful methods include setting it to either 1 [m^3 s^-1]/Wall Distance, or 1 [m^5 s^-1]/Volume of Finite Volumes. This causes the elements near walls or small elements respectively to become stiffer than the general mesh. When carefully chosen it can help maintain mesh quality and reduce elements inverting. Have a read of Solver Modelling/Basic Capabilities modelling/Mesh Deformation in the documentation. Glenn Horrocks |
June 17, 2009, 15:44 |
How can I define the mesh stiffness in CFX ?
chris
Rep Power: 16 |
How can I define the mesh stiffness in CFX ? CCL object how define this object
chris |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 00:27 |
Mesh stiffness in 1 way FSI | vmlxb6 | CFX | 4 | February 15, 2011 16:17 |
FSI mesh stiffness help | realanony87 | Main CFD Forum | 2 | June 21, 2009 15:29 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
