-   -   How to set up a CFX Pre? (http://www.cfd-online.com/Forums/cfx/65955-how-set-up-cfx-pre.html)
winglet July 1, 2009 22:28
hi All,
I am int interested to see flow behavior on wings and wing with winglet.
I have the following test conditions :
Stagnation temperature =322 K
dynamic pressure : 41KN/M^2
Mach = 0.8
Re =17 million per unit length.
with these test conditions ,how to apply BC in CFX Pre?
ghorrocks July 2, 2009 02:19
Look up the definition of all these terms. Then solve a simultaneous set of equations to determine what they mean in terms of pressure, velocity, density etc.
Then you apply the boundary in CFX-Pre, probably in terms of velocity and temperature inlet and pressure outlet.
winglet July 2, 2009 04:04
Hi ghorrocks,
Thanks for your reply.
I able to caalculate velocity and temperature from the availble data. I am not sure on exit boundary condition,because the data does not provide any thing on outlet.
can I use relative static pressure as zero at outlet?
ghorrocks July 2, 2009 06:53
The exit pressure will be whatever the ambient pressure is. Unless you know otherwise then I would guess 1 atm absolute. You would then use 1 atm as your reference pressure and set the exit pressure to 0 gauge pressure.
winglet July 2, 2009 12:46
Originally Posted by ghorrocks (Post 221205)
Thanks. I set up CFX run today .Let me see how it will run.
