Home > Forums > CFX
CFX *.def file
Old   July 10, 2009, 09:50
Exclamation CFX *.def file
Anna Encheva
anna_67 is on a distinguished road
is it possible to use the *.def file to change some preprocessing data and run a new simulation or one needs the *.cfx file. Thanks
anna_67 is offline   Reply With Quote
Old   July 10, 2009, 10:06
LKF
LKF is on a distinguished road
There are a few different ways to modify a .def file.
1. In Solver Manager > Tools > Edit Definition File
2. Open the .def file in PRE
3. Create a ccl file and run from command line: cfx5solve -def deffile.def -ccl cclfile.ccl
LKF is offline   Reply With Quote
Old   July 10, 2009, 10:15
wu
whiz is on a distinguished road
and also you can do like this:
cfx5cmds -read -def ***.def -text aa.ccl
then you can edit the aa.ccl
use the command:
cfx5cmds -write -def ***.def -text aa.ccl
to change the def file.
whiz is offline   Reply With Quote
Old   July 10, 2009, 11:56
Rui
Rui's Avatar
Rui Igreja
Rui is on a distinguished road
Yes, the *.def file is enough.
I think (but not sure) that, in a simple way of putting it, the *.def file = *.cfx file + mesh
Rui
Rui is offline   Reply With Quote
Old   July 10, 2009, 13:30
ckleanth's Avatar
George
ckleanth is on a distinguished road
nah its more like *.cfx file = mesh + all ccl ; *.def file = mesh + ccl required for the run.
Top 4 tips
1. Knowledge is everything and Ignorance is dangerous.
2. Understand your limitations and try to eliminate them.
3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window.
4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials
ckleanth is offline   Reply With Quote
Old   July 10, 2009, 16:08
Rui
Rui's Avatar
Rui Igreja
mate, that simulation is taking its time to converge
You are right, the *.cfx file also contains the mesh information.
The documentation (ANSYS CFX-Pre File Types) says: "The case file (*.cfx) contains the physics data, region and mesh information for the simulation...". I've checked, and it's true
About the *.def file, it says "*.def file contains the specification for the whole simulation, including the geometry, surface mesh, boundary conditions, fluid properties, solver parameters and any initial values."
Surface mesh????!!!!
And the *.cfx file also contains solver parameters information, etc
But, answering Anna question: "You can load a definition file back into ANSYS CFX-Pre to recreate a simulation"
Rui
Thread Tools
Trackbacks are On
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 14:00
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
