July 25, 2009, 12:42 |
Question about Fortran Compoler
Zoltan Turzo
Rep Power: 17 |
Dear CFX Masters!
Please answer my question! The installaton manual of ANSYS 12.0 says, that if you want fortran user routines you need Intel Visual Fortran (I VF) 10.1, and Microsoft Visual Studio (M VS) professional 2005 or 2008. I have I VF 10.1, but i have M VS 2003 profesional only. Does it work, or I have to get M VS 2005 or 2008 professional? Regards Z. Turzo |
July 27, 2009, 19:26 |
#2 | |
Jack
Rep Power: 16 |
#1 Mr. ckleanth did start the discussion: assuming you installed fortran correclty and before compiling at the command line window, type "ifortvars" #2 rogbrito (myself) said: Donīt forget to include the PATH in the environment variables of your Windows: C:\Program Files\ANSYS Inc\v120\CFX\bin\ #3 Mr. J.Ramon said: Thanks guys but i havenīt got it works, i donīt know what can i do... #4 Mr. Lance also said: Could it be that you have spaces in the path? "C:\Archivos de programa..." #5 Mr. J.Ramon said: C:\Program Files\... has spaces too.. prfff i donīt know what could be the problem Thanks. #6 Mr. rogbrito (myself again) said: You have to install (only for Windows XP 32 bits) MS Visual C++ 6.0 or .NET 2003 or MS Visual Studio 2005 Express Edition. Quote: I saw in the forum a threads similar like this but without answer, simply what ocurr is when i write in the CFXīs command editor the order: (all is about the 9 tutorial, like others threads): ! system ("cfx5mkext Pipevalve_inlet.F") < 1 or die; in the comman window (ms-dos) appear the next error: ------------------------------------------------ ifort: error: could not find '\Bin' An error has ocurred in cfx5mkext: C:\Archivos de programa\Intel\Compiler\fortran\9.0\IA32\Bin\ifort could not be started, or exited with return code 255: . ------------------------------------------------ And the compiling process fail. If anyone could help me about this issue, iīve searched in google and in the forum, but i havenīt found something that works. Iīm working with ansys cfx 11, with intel fortran compiler 9.0, in a os windows xp pro (32 bit) with an AMD Athlon 64 X2 Dual Core processor and 2 GB RAM. THANKS IN ADVANCE. #7 Mr. J.Ramon said: Thanks to all, finally iīve got the compiler works, the problem was i hadnīt installed the microsoft sdk platform, i had installed ms 2005 and i was thinking when i installed ms 2005, the microsoft sdk platform had been instaled with ms 2005, but it hadnīt been installed with this, and that was the problem, i installed microsoft sdk platform and added some values in the PATH and LIB variables at enviroment variables and system variables, and finally it worked, and i got do the tutorial 9 with ANSYS CFX CEL fucntion. THANKS A LOT TO ALL PEOPLE FOR YOUR ADVICE, THANKS, THANKS. Please, donīt forget to put the CFX files in the path of Windows XP 64/32: C:\Program Files\Microsoft Platform SDK\Bin\.;C:\Program Files\Microsoft Platform SDK\Bin\WinNT\.;%IFORT_COMPILER91%\IA32\Bin;%IFORT _COMPILER91%\EM64T\Bin;C:\Program Files\ANSYS Inc\v110\CFX\bin Quote: Originally Posted by J.Ramon Thanks to all, finally iīve got the compiler works, the problem was i hadnīt installed the microsoft sdk platform, i had installed ms 2005 and i was thinking when i installed ms 2005, the microsoft sdk platform had been instaled with ms 2005, but it hadnīt been installed with this, and that was the problem, i installed microsoft sdk platform and added some values in the PATH and LIB variables at enviroment variables and system variables, and finally it worked, and i got do the tutorial 9 with ANSYS CFX CEL fucntion. THANKS A LOT TO ALL PEOPLE FOR YOUR ADVICE, THANKS, THANKS. Quote:
July 28, 2009, 13:27 |
Zoltan Turzo
Rep Power: 17 |
Thanx!
I will try to compile. Regards Turzoz |
Display Modes | |
Fortran question | Noureddine | Main CFD Forum | 12 | October 31, 2007 13:07 |
Question for Fortran experts | jojo | Main CFD Forum | 5 | September 27, 2006 08:30 |
Fortran Question | Vishwas | Main CFD Forum | 1 | April 12, 2006 17:56 |
some question about moving grid and fortran | shure | Siemens | 4 | April 18, 2005 22:12 |
Stack frame size, Origin 2000, fortran, a question. | Sergei Chernyshenko | Main CFD Forum | 4 | February 22, 1999 14:24 |
