Home > Forums > CFX
system / solver capacity
Old   July 29, 2009, 00:41
Default system / solver capacity
jai
jaikrishna
jai is on a distinguished road
how do i calculate maximum or optimum amount of elements can be solve in a machine(based on number of node, ram..)?
and
jai is offline   Reply With Quote
Old   July 29, 2009, 06:51
stumpy is on a distinguished road
While there are some rules of thumb, the memory required will depend on the particular case and the models used. If you run a case with x number of nodes, then just look in the out file before the first iteration to see how much memory was used. Memory will scale linearly with the number of nodes - so 2x nodes requires twice the memory etc.
stumpy is offline   Reply With Quote
Old   July 29, 2009, 13:46
jai
jaikrishna
if my problem having x number of elements and I'm solving by serial type (ie: 1 processor) so it utilize some y amount of memory.
this same x number of elements solving by 2 processors means it utilize 2*y memory.
Is this correct?
mean time I'll check it
I've 4 processors and 4 node license and 8GB ram.
how many number of element i could run optimally?
how to calculate to know this?
if my problem size is 10 million elements and how do i know minimum configuration require for this?
Old   July 29, 2009, 19:11
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
The size analysis you require should be determined by a sensitivity analysis. After you have determined the mesh size and timestep size you require you then look at what computer is required to run it.
Why don't you run a 1M and a 2M node simulation and look at the memory use? Then you can extrapolate it out to the size you require.
Old   July 30, 2009, 13:04
jai
jaikrishna
please could you explain in details with one example
Old   July 31, 2009, 02:51
shogologo is on a distinguished road
Check "CPU and Memory Requirements" section under ANSYS CFX-Solver Manager User's Guide.
shogologo is offline   Reply With Quote
Thread Tools
Trackbacks are On
Conjugated solver for momentum and energy equations system makaveli_lcf OpenFOAM Running, Solving & CFD 3 April 14, 2009 02:16
Linear system solver elias FLUENT 0 November 19, 2008 10:30
questions concerning solver and multigrid methodes youradvice Main CFD Forum 1 August 6, 2007 15:27
block tridiagonal system solver for periodic bc Abdullah Main CFD Forum 8 February 23, 2007 14:15
Pressure based and Density based Solver Xobile CD-adapco 1 November 30, 2004 22:13
