Wind Turbine Transient
Old   September 10, 2009, 18:23
Default Wind Turbine Transient
Sergio Brett
sergiorbrett is on a distinguished road
Hi all,
I am traying to simulate the transient behaivour of a wind turbine from 0 rpm to operations ones (72 rpm). I want to take into account the torque produce by the blades in order to estimate the rotational speed at the end of each timestep usin the ecuation
Wend=((Torque*DeltaT)/inercia momentun)+Wstart
I have a problem when I want to assign the Wstart, because and the begining I know that its value is 0, but at the end of each timestep, I need to assign the previus Wend to the new Wstart, in order to estimate the new Wend and so on.
I am using cell expressions to define this, but I do not know how to calculate the angular velocity of the previus timestep.
If anyone know how to do it, please let me know.
Thanks
sergiorbrett is offline   Reply With Quote
Old   September 13, 2009, 23:48
Sergio Brett
Hi all,
My problem is I don't know exactly how CEL works. Are the expressions evaluated at the end of each timestep or at the begining?, I did the tutorial of FSI, and I understood that the cel expressions are evaluated at the begining, then according with the results are set the boundary conditions to the next timestep.
With this in mind, I wanted to set the new rotation velocity to my turbine for each timestep, using the previus rotation velocity, and I want to calculate this velocity with.
areAve(Rotation Velocity)@tip blade / Tip Radius.
I used the velocity calculated with this equation with a steady state run, with the rotor rotating at 72 rpm and they have almost the same value. But when I try to use it in the transient run, it calculate a diferent velocity with not physical sense.
Could anyone explain to me how the CEL expression works.
Thanks
Old   September 14, 2009, 22:12
Steve Hansel
hansel is on a distinguished road
Originally Posted by sergiorbrett View Post
Hi all,
Thanks
I believe the best way to test wind turbines is spin them at various fixed rates, then measure the torque. Power = torque * rps. This will let you find the peak power point of your turbine and will help you know what kind of generator / alternator to put on it.
hansel is offline   Reply With Quote
Old   September 14, 2009, 22:37
Sergio Brett
Hi hansel.
You are right, the best way to study wind turbines is simulating steady states at diferents spin velocity, but I am studying the transient of a small wind turbine from 0 rpm to operational velocity with constant wind speed. That is why, i need to take into account the inertia of the rotor, the torque generated by the wind and the torque used by the generator.
Thanks
Old   September 14, 2009, 22:38
Sergio Brett
Hi hansel.
Thanks
Old   September 15, 2009, 10:20
Steve Hansel
Hi hansel.
Thanks
Ah I understand. I have considered doing the same thing to see if a VAWT will self start. Unfortunately, I have no idea how to do that.
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Compute the power of small wind turbine. Luolin FLUENT 9 May 27, 2013 14:52
Wind turbine simulation Saturn FLUENT 1 June 16, 2006 02:12
Wind turbine simulation Saturn Main CFD Forum 1 June 12, 2006 03:57
please help me to work on wind turbine san FLUENT 0 March 13, 2006 01:56
