Two Ways FSI: How I can Export the Deformed Mesh back to the SolidWorks
I am doing FSI simulation of valve and at some point CFX can not move the mesh any more and I receive negative element error. I was thinking of re-meshing and interpolating the old results into the new mesh and go on but to do this I have be able export the deformed structure to the CAD software. Does anybody know how I can export a deformed geometry to CAD program (for example solidworks)? The simplest way could be creating an IGES file but I don't know how to make it. I appreciate your help. Ahmad |
Question is bit confusing,whether you want to export from post/pre or from meshing softwares. Its possible only in meshing software where you can export to IGES format.. I feel you may be doing transient simulation in CFX,If that is the case to avoid this you can do following things, 1) mentain uniform mesh size at stationary and moving domain(Preferably hex mesh) 2) Set expert parameters like "Check isolated regions to false" 3) Your time step value (Very important) |
To make my question clear, you know that one of the major problems in FSI is mesh being folded (resulting negative element error) when the CFX is not able to move the mesh anymore. One solution I thought is extracting the deformed geometry of the structure at the point when the CFX can not move the mesh, remesh it, interpolate the solution of into the new mesh and go on with FSI analysis with new mesh. Now the only way you can remesh the deformed domain is to have it in a format (for example IGES) which you can open it in the CAD or mesh generator. Simply I would like to exprot the deformed geometry from CFX-Post to my mesh generator. Thank you for your help. Ahmad |
Hi Ahmed,
Please I was wondering if you found the solution to your problem as I have a very similar problem. Cheers. |
Hi
I have not done any problem of such kind in CFX but I don't think it's possible because CFX is solving the mesh not the Geometry. It is the mesh from Meshing Software( like ICEM CFD) which we export for solution, not the geometry...isn't it? |
You can convert mesh to parasolid file in FE Modeler. Drag the solution from static/transient structural to FE Modeler. In this link you've got an explanation how to make it: https://caeai.com/sites/default/file...0Workbench.pdf It's very simple. Best regards |
