August 26, 2009, 10:07 |
Finned Pipe Trouble
Fabio
Rep Power: 16 |
Hi, I need to solve a trouble with cfx used to simulate an example of "fin pipe" as in figure below, where the lower face of pipe trasmit a heat power and where ther is a flow of water.
The blue zone is a water domain. If each single fin separates blue zone into multi-parts domain, as we see in figure, the solver fails imediatly and providing this error message: An error has occurred in cfx5solve: | | | | Error interpolating results onto the new mesh: C:\Program | | Files\Ansys Inc\v120\CFX\bin\winnt-amd64\solver-hpmpi.exe exited | | with return code 1. Otherwise if the fins are more little then pipe's height (as second figure) , domain is considered as a single part, and the solver correctly runs. Could you explain me the reason of that mistake? ps for both geometry i have defined in cfx-pre the same elements:
Thanks |
August 26, 2009, 18:29 |
Rep Power: 143 |
For the case with separate fluid domains, put a separate inlet and outlet boundary condition on each face. I am not sure that's the problem but its worth a try.
August 27, 2009, 04:55 |
Fabio
Rep Power: 16 |
yes, with that solution, i'm sure working fine, but i think that are another way (more quick) to set cfx-pre...don't u think so?
August 27, 2009, 07:18 |
Rep Power: 143 |
On the geometry you show it will only take a few minutes to set it up as I describe. How much quicker do you want? Are you going to spend days trying to speed the setup up by 5 minutes?
August 27, 2009, 07:24 |
Fabio
Rep Power: 16 |
yes yes, u are right, it'was only my curiosity
August 28, 2009, 03:44 |
Simmilar problem
mistry
Rep Power: 17 |
Dear sir,
I am facing same problem for analysis of fluid flow with insert like for modeling i prepared one cylinder then i inserted a thin plate as you deed and then i cut that geometry.. it generates to parts for inlet i select to portions same way for outlet 2 portions and outer wall... means by putting this plate i am splitting the flow in two domains.... i am getting the same error as you are... return code 1. please guide me what to do... |
August 28, 2009, 06:41 |
Rep Power: 143 |
Or to put it more clearly a boundary condition should not span multiple domains. Boundary conditions which span multiple parts of the same domain which are not connected (eg two fluid regions in one fluid domain with a solid region in between) should also have separate boundary conditions on each region.
August 31, 2009, 02:20 |
solution
#9 |
mistry
Rep Power: 17 |
Yes, thank you sir. i spend hours to have solution and i got it..
thanks a lot |
flow in perforated pipe distributor | pertupd | ANSYS | 0 | August 12, 2009 08:36 |
calculation of thrust thrugh a pipe with CD nozzle | izhar | Main CFD Forum | 0 | February 28, 2009 09:22 |
My Revised "Time Vs Energy" Article For Review | Abhi | Main CFD Forum | 2 | July 9, 2002 09:08 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
