use equations
Old   September 4, 2009, 05:57
Cool use equations
Ema
Tuffy
Ema is on a distinguished road
Hi everyone!
I must use an equation in CFX to set a condition about the voltage.
The idea is to create something like this:
if the temperature is lower than 90° use a voltage of 60 V. If not decrease the voltage until the temperature is not lower than 90°.
do you know exactly which is the meaning of the following equation?
step((maxVal(Temperature)@REGION:B64-90 [K] )/1[K])*60[V]
how much is the value? 60 V if?
please, help me!!!!
thanks,
Ema
Ema is offline   Reply With Quote
Old   September 4, 2009, 06:07
Ema
Tuffy
i've also tried to implement the following expression:
volt= 60[V]*(1/(1+e^(5*(maxVal(Temperature)@REGION:B97-90[K])/1[K]))) but my update failed...
Old   September 4, 2009, 06:28
ckleanth's Avatar
George
ckleanth is on a distinguished road
your equation doesnt make any sence
step function returns 0 or 1 and your conditions should be non dimensional (thats why you divide the temperature by 1/[K] )
if you multiply by 60[V] then your expression has value either 0*60[V] or 1*60[V]
if you want to to create some feedback control search in the cfx manual for "Example: Feedback to Control Inlet Temperature"
Top 4 tips
1. Knowledge is everything and Ignorance is dangerous.
2. Understand your limitations and try to eliminate them.
3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window.
4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials
ckleanth is offline   Reply With Quote
Old   September 4, 2009, 06:54
Timon is on a distinguished road
You don't need to define the unit [K] after your maxVal(Temperature)@.... statement, as the value returned already has unit.
Timon is offline   Reply With Quote
Old   September 4, 2009, 07:59
ckleanth's Avatar
George
the units are for the 90[K]. the step function can look something like:
step( (T - 90 [K]) / 1[K] ) or
step( (T/1[K] - 90 )
Top 4 tips
Old   September 4, 2009, 08:02
Ema
Tuffy
exactly. Otherwise CFX will say you that the values are not correct.
What about my equation? why no sense at all? i was thinking to implement like a sigm function to multiply with the voltage...
True, disregard my previous post...
Old   September 4, 2009, 08:08
ckleanth's Avatar
George
well you said you wanted to do some feedback. I replied that if you want to to create some feedback control search in the cfx manual for "Example: Feedback to Control Inlet Temperature". your equations as it stands dont do that
Top 4 tips
Guide: Writing Equations in LaTeX on the CFD Online Forums pete Site Help, Feedback & Discussions 27 May 19, 2022 03:19
Maths problem when deriving conservation of energy equations. Demonwolf Main CFD Forum 1 June 15, 2009 14:21
Equations Andres Bernal Ortiz CFX 1 January 6, 2007 11:56
? fluctuating equations for homogenous shear turb. ff_fan Main CFD Forum 1 September 20, 2002 07:39
Euler equations? Jan Ramboer Main CFD Forum 2 August 19, 1999 01:58
