relaxation factor for coupling in FSI simulation |
September 10, 2009, 08:40 |
Rep Power: 16 |
Hi All,
I am currently working on a project in FSI which I need to use non-constant value for under relaxation factors of the coupling. For Example, I want to use relaxation factors of 0.1 for the first few stagger iterations and then change it to 1. I have tried putting in an expression to tell the solver to do what I want above but CFX returns an error saying that only numeric value can be used. Is there anyway to do this? Also, I thought if it cannot be inserted in the CFX-pre(CCL), then maybe it can be done by going into the MMS and overwrite the value at the beginning of each stagger iteration. However, I am trying browsing the data location of the relaxation factor of the coupling but I couldn't find anything since I don't know its solver name and not even sure that the value is stored in MMS of CFX. Any idea would be appreciated! Cheers taedeneo |
September 10, 2009, 18:22 |
Rep Power: 143 |
The easiest way sounds like stopping the simulation, resetting the URF and restarting. This can all be scripted so it still can run efficiently.
September 11, 2009, 03:09 |
Rep Power: 16 |
Hi Ghorrock,
Thanks for your reply. Could you give me some guideline of how to do the scripting? Cheers |
September 11, 2009, 07:29 |
Rep Power: 143 |
The documentation discusses starting the CFX solver from the command line. This gives you all the solver run-time options. Then probably use a CCL file to change the things you wish. Look for the commands "cfx5cmds" and "cfx5solve".
Display Modes | |
BCs in an FSI simulation of a flexble pipe | vivekcfd | OpenFOAM | 10 | January 8, 2010 04:14 |
FSI simulation is DEAD SLOW | Lance | CFX | 6 | September 12, 2009 09:00 |
FSI Simulation unsing ANSYS Multifield | k_buz | CFX | 2 | April 6, 2009 17:40 |
FSI TWO-WAY SIMULATION | Smagmon | CFX | 1 | March 6, 2009 13:24 |
Restart of FSI simulation | V. Kumar | CFX | 3 | July 20, 2006 13:23 |
