boundary layer specifications for laminar flow
Like Tree2Likes
  • 1 Post By Jim
  • 1 Post By ghorrocks
Old   November 20, 2007, 03:24
Default boundary layer specifications for laminar flow
ranjith
I am new to cfd. I am modelling blood flow through a pipe with a valve at the centre. Assuming the flow is laminar is the boundary layer resolution and the number of prism layers important. I could find specifications(y+ ranges) for turbulent flow but none for laminar flow.would greatly appreciate any help
Old   November 20, 2007, 03:46
Default Re: boundary layer specifications for laminar flow
frank
in my opinion, y+ is only for turbulence flow, not for laminar flow.
Old   November 20, 2007, 05:25
Laminar flows are strongly influenced by the boundary layer, but the boundary layer is much thicker than in turbulent flow so a coarser mesh can sometimes resolve it. Depends on exactly what Reynolds number you are at. Inflation layers are still useful until you are doing very low Reynolds numbers, ie Stokes flow.
Blood has strong non-newtonian properties so you may well need a fine boundary mesh to resolve these non-linear properties. I have never modelled blood so am no expert on it but you should check it out.
Old   November 20, 2007, 07:50
Jim
If you assume for a moment that you have a constant viscosity (I know you haven't but go with it), then since the flow is laminar you basically have a Hagen-Poiseuille flow, i.e. a parabolic velocity profile. Therefore (IMHO) you should use a power law grid distribution so that you have equal increments of velocity across each cell. For example, if u_wall=0 and u_max=1 m/s, and you use 20 cells across the channel width, then each cell should be at the position that correlates to velocity profile increments of 0.1 m/s. This will give you the refinement you need at the walls. If you have problems understanding this rather wordy explanation, draw a parabola on some graph paper(y is position, x is velocity) and mark off the y positions that correlate with equal increments in x. Good luck.
wht likes this.
Old   November 21, 2007, 00:38
ranjith
Thank you Frank, Glenn & Jim for ur suggestions
Old   October 13, 2017, 07:13
Trudix
Trudix is on a distinguished road
Hi guys, even though this post is pretty old allready, I have a similar question. I'm new to CFD and I'm trying to model a microchannel device. According to Glen Horrocks: "Inflation layers are still useful until you are doing very low Reynolds numbers, ie Stokes flow." To which magnitude of Re Inflation-layers make sense? Since I'm dealing with really low Re, should I just use my regular tedrahedron-mesh near the walls. Is a mesh refinement near the walls requiered? Thanks a lot for your help. It's very much appreciated.
Trudix is offline   Reply With Quote
Old   October 13, 2017, 17:59
You should consider why inflation layers are recommended in the first place. They are useful in high Re flows as the flow variables change rapidly in the boundary layer region and a fine mesh is required to capture this rapid change so the flow is accurate. So the mesh resolution you require depends on how rapidly the variables change.
For microfluidic devices you rarely get boundary layers forming and you are more likely to have laminar flow, possibly fully developed. In fully developed flow the variables change smoothly across the entire section - which means there is no rapid change near the wall, so no inflation layers are required. But a laminar flow which is not fully developed may require additional resolution at the wall to capture the start up behaviour.
As always, it is problem dependant. So do a mesh sensitivity study and find out in your case.
sargordan likes this.
Old   October 16, 2017, 08:09
Trudix
Thanks a lot for your help ghorrocks!
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Boundary Layer of Laminar Flow over a Flat Plate Blasius_Pohlhausen_Crocco Main CFD Forum 12 September 30, 2013 17:35
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
Boundary layer strategy for port flow case? MaxCFM Main CFD Forum 1 September 9, 2009 06:09
Unsteady Boundary Layer Flow Wen Long Main CFD Forum 0 July 29, 2002 23:08
