two-way coupling problem in multiphase simulation
Old   September 13, 2009, 23:04
Default two-way coupling problem in multiphase simulation
ManChiu
jeff_F is on a distinguished road
I am working on the simualtion of spray. The breakup models I used are LISA and TAB. I am using k-Epsilon model for turbulence, two-way coupling and schiller Naumann for drag force model. Turbulent dispersion force is on with default Eddy viscosity ratio limit.
The setting seems alright. However, there is huge difference between the spray droplet speed and the flow field's speed (Max. speed are 24ms^-1 and 0.27ms^-1 respectively). Is there anything I can do for improving the two phase coupling performance?
Thanks!
jeff_F is offline   Reply With Quote
Old   September 14, 2009, 05:44
seaharrier is on a distinguished road
I suggest you check the droplet diameter and other parameters pertinent.
What you have set as you said is not the matter, you needn't rework them.
Look into the help docs carefully.
seaharrier is offline   Reply With Quote
Old   September 16, 2009, 00:50
Mehul
Mehul157@yahoo.com is on a distinguished road
Hi Jeff,
I think, you need to check your physics of the problem first, What is an approximate size of your particles and the particle loading ( no of particles/ m3 of Air). If particles are too big and if you think that they can change the momentum of the air, then only use two way coupling other wise one way coupling is good. Please check how you have defined the density of the spray particles?
Mehul157@yahoo.com is offline   Reply With Quote
Old   September 16, 2009, 10:35
ManChiu
Thanks! I will check that
Old   November 28, 2020, 13:35
Ganesh Arun Naik
GaneshNaik is on a distinguished road
Hello everyone,
I am using CFX transient lagrangian particle tracking model to track particles and determine their concentration in a clean room.
The particle volume fraction is very low (< 10^-8). I am using full buoyancy model. The particles are to be simulated for different particle temperature and hence varying buoyancy.
The particles size ranges from 0.5 micron to 5 micron.
Do i need to use two way coupling or is one way coupling sufficient?.
Thank you all.
Ganesh
GaneshNaik is offline   Reply With Quote
Old   November 28, 2020, 20:33
You should decide on the coupling by the significance of the effect of one phase on the other. The particles are affected by the air flow, of course - that is why you are using a particle tracking model. But it would be very unusual if such small and sparse particles then had a significant effect on the air flow.
In that case you can model this as one-way coupling.
But I am just guessing as I do not know what you are doing, why you are doing it and what physics is important. You have to make your own decision.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   December 1, 2020, 10:13
Ganesh Arun Naik
Hello Glenn,
Thank you for the reply. I am trying to simuate the effect of particle temperature on the buoyancy.The particles are generated by an injecion molding machine in a cleanroom. I would like to check how the temperature effect the trajectory and hence concentration of particles in the clean room.
Thank you,
Ganesh
Old   December 1, 2020, 17:04
Does the temperature make the air have buoyant effects? Then the moving air would affect the particles?
Or are you saying the temperature of the particles affects the buoyancy? This sounds highly unlikely as the particles (if they are some sort of solid or polymer) are going to have a density far larger than the surrounding air, so a small change in the density of the solid due to temperature is going to have no significant effect.
Old   December 2, 2020, 04:23
Ganesh Arun Naik
Hello Glenn
Yes the temperature makes the air have buoyant effect. The material is polypropylene particles. I have used full buoyancy model with ideal gas as continuous fluid . And thermal energy as heat transfer for air and particle temperature for particles.
Thank you,
Ganesh Naik
Old   December 2, 2020, 05:06
In that case it sounds like this case is two way coupling as the particles affect the air flow. In this case the coupling is indirect as it is through heat transfer, but it is indeed coupled. So you need a two way coupled model.
Have you considered doing this with a Eularian particle model? It may well be easier and will probably be much faster and easier to get to a mesh independent solution.
Old   December 2, 2020, 05:43
Ganesh Arun Naik
Hello Glenn,
Thank you for the reply. I have not tried it using Eularian Model. I will read about it.
Thank you,
Ganesh
Continuous casting simulation problem luke.christ FLUENT 6 November 24, 2020 07:14
Problem with interface in a wind turbine simulation be_inspired FLUENT 2 March 7, 2011 23:46
Backflow in eulerian multiphase simulation xeusater FLUENT 0 June 26, 2009 07:50
Multiphase radiation in Ansys 10 problem Luk CFX 2 June 5, 2008 11:31
Multiphase flow problem icedou FLUENT 6 July 10, 2005 02:52
