Problems with adding two meshes together in CFX Pre |
September 23, 2009, 05:25 |
Rep Power: 16 |
Hej,
i ve a problem when i try to load two meshes in CFX Pre. The first mesh consists of one solid 3d region with some holes. The other mesh contains 7 3d solid parts which fit into these holes. If i load the mesh with the 7 3d regions, my other mesh, that i loaded before, dissapears. The BC are still set for it, but it can not be displayed anymore. Is there anything wrong with the mesh file? To be honest, i already did several meshes, but never had this problem. Usually i just load 2 meshes and everything works fine, but not this time. Any suggestions? Regards |
September 23, 2009, 05:36 |
Rep Power: 16 |
Hej,
is it possible that it is not allowed to name a mesh file with a "-" like part1-7? If i rename it, it seems to work... Regards |
September 23, 2009, 08:08 |
Bharath kumar
Rep Power: 17 |
you may check your units while importing to Pre.different units(mm,m) may cause the problem
CFX Pre Hide symmetry symbols | alvid | CFX | 2 | August 15, 2007 11:34 |
CFX 5.7.1 PRE and solver won't start | daniel | CFX | 1 | January 20, 2006 10:09 |
Problems installing CFX on Sun Unix Platform | Haley | CFX | 2 | November 9, 2001 09:52 |
unstructured grid | sreekanth | Main CFD Forum | 1 | August 6, 2001 15:09 |
CFX problems no NT? | Michael Bo Hansen | CFX | 0 | September 28, 2000 09:55 |
