ERROR #001100279 NAME_MOD: Error finding variable "PRES" |
September 21, 2009, 09:50 |
Rep Power: 16 |
Hej,
if I run my definition file i get the following error msg in the solver. | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | NAME_MOD: Error finding variable "PRES" In my simulation i defined a new material, after adding it to the domain i get the error msg, without the computation runs. I set a new solid, and took an expression for density, specific heat and conductivity. I defined them in a csv table and just wrote in "Material properties" Material.Density(T,p) as an expression. I m not sure if i did it correctly, so hopefully you can help me Regards |
September 21, 2009, 19:32 |
Rep Power: 143 |
I don't think you can have a solid density a function of pressure. The pressure variable does not exist in solid regions. Or is the solid for particle tracking?
September 22, 2009, 06:20 |
Rep Power: 16 |
Hej,
thanks for the answer. My bad, for sure i cant set a pressure value for a solid :/ Thx a lot Regards |
Display Modes | |
Instalation on ubuntu 710 | basilwatson | OpenFOAM Installation | 17 | March 16, 2012 21:16 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 05:35 |
Problems with additional variable | Krishna Premi | CFX | 1 | October 29, 2007 09:19 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 05:27 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
