Help using an understanding y+
Old   September 30, 2009, 09:46
Default Help using an understanding y+
siw
Stuart
siw will become famous soon enough
I'm running some simulations for the external aerodynamics of a streamlined body. I've made a mesh in CFX-Mesh and set the first layer height of the surface prisms by imputting a y+ = 30 and the Reynolds number based on the body length. I ran the simulation with the SST model. Now in CFX-Post I've plotted surface contours of Yplus (as CFX-Post terms it) and the data ranges from about 6 to 72. Is this data even comparing the CFX-Mesh inputted y+ with the target y+ values all over the body?
So my questions are: Is this contour plot showing me data that states I need to remesh with a different y+ value? I've looked at various texts about y+ and all they say is the equations with shear stress, skin friction coeffcient etc and not how to realistically put numbers into.
Thanks.
siw is offline   Reply With Quote
Old   September 30, 2009, 19:34
You will need to do a sensitivity analysis on your simulation to determine what to do. Refine the mesh and see if the drag (or whatever the parameter of interest is) changes. If the refined mesh gives different results then you have to think about further refining the mesh. If not then it is OK.
Old   October 1, 2009, 04:05
siw
Stuart
Thanks,
So plotting Yplus in CFX-Post is of no use and I should only alter the CFX-Mesh Stretch variables until solution independence occurs?
BTW, from your experience what is an acceptable aspect ratio for the prism elements? Having specified a first layer height via the y+ option surface spacing in the x direction would be based on the aspect ratio limits for an initial mesh to get a good start before refinement.
Old   October 1, 2009, 07:10
I did not say no use, I just said purely basing mesh sizing off y+ is not a good idea. The y+ figure is a guide to give you a starting point for general simulations. However if you are integrating to the wall (eg using turbulence transition model) then it becomes more important and you need to make sure the critical boundary layer regions are not exceeding 1 by too much - but still a sensitivity study is the way to make sure you are right.
Aspect ratio can go quite high in boundary layer elements, 100 or even 500 is OK providing the ends are perpendicular to the wall and the long edge parallel to the wall. Elements with aspect ratios this high in the internal flow regions will cause problems. Again, this is problem dependant and you should do a sensitivity study to determine the mesh you need both normal and tangential to the wall.
Old   October 4, 2009, 10:23
Syed Mushahid Hashmi
Hashmi is on a distinguished road
Actually y+ is a non-dimensional distance, The distance from the wall measured in viscous lengths - or wall units -
It is denoted by
y+ = distance from the wall / viscous length scale
viscous length scale = kinematic viscosity/(sqrt(wall shear stress/density))
close to the wall viscosity and shear stress are important parameters, therefore they are present in the definition of viscous length scale.
Just like Reynolds number which gives relative importance of inertial and viscous forces in order to characterize the flow (laminar or turbulent).
the y+ determine the the relative importance of molecular and turbulent viscosity closed to the wall, e.g The viscous contribution drops from 100% at the wall (where y+=0) to 50% at y+=12, and is less than 10% at y+=50.
for detail see the book Turbulent flows by Pope
SMH Hashmi
Hashmi is offline   Reply With Quote
Understanding interFoam sega OpenFOAM Running, Solving & CFD 26 February 10, 2022 03:21
Understanding of channelOodles and oodles solver fs82 OpenFOAM 1 September 23, 2009 10:36
Need Help Understanding RMS residual calculation TWaung CFX 1 September 22, 2009 18:21
understanding dual-time stepping srinath Main CFD Forum 1 August 11, 2008 11:05
LUSGS understanding Gustavo Main CFD Forum 0 February 14, 2007 10:12
