October 3, 2009, 06:08 |
URANS in ANSYS CFX
Ben
Rep Power: 16 |
Hi ,
I have completed some RANS simulations of a submarine model at a relativley high Re number. I am now trying to start a URANS simulation, How do you go about starting an URANS simulation in ANSYS CFX? How does this vary from a transient run in ANSYS CFX or is URANS a transient run with RANS model applied? I have tried to look in the ANSYS help document with out much luck, any help would be great, Thanks, Ben |
October 5, 2009, 18:48 |
Rep Power: 143 |
URANS is, in its simplest form, simply using the RANS equations in a transient simulation. As the Reynolds averaged NS equations assume steady state you have to be careful that there is a separation between turbulent timescales and flow timescales and that you simulation is correctly resolving this timescale difference.
URANS is the simplest approach for unsteady turbulence simulations. If its underlying approach is not applicable then you need to move to more advanced techniques like DES, SAS or LES. Shedding of vorticies behind a bluff body is an example which is tricky with URANS and lends itself more to the DES/SAS/LES approaches. |
October 5, 2009, 19:45 |
Ben
Rep Power: 16 |
Thanks for your help Glen,
Does ANSYS CFX have the ability to do DES or SAS simulations? |
October 6, 2009, 17:35 |
Rep Power: 143 |
Yes, CFX can do DES, SAS and LES.
how to map resultd from cfx to ansys? | ritesh | CFX | 2 | June 1, 2011 07:52 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 01:10 |
MFX: weired force transfer from cfx to ansys | zyf | CFX | 3 | October 7, 2006 03:08 |
FSI using CFX and ANSYS | Bi Chang | CFX | 2 | May 10, 2005 04:47 |
ANSYS to acquire CFX | Fred | FLUENT | 0 | February 18, 2003 21:04 |
