Differences in out. file and function results |
September 22, 2009, 10:56 |
Lukasz
Rep Power: 17 |
Hi all,
I was digging through the forum and found similar problems with no answer. I am trying to simulate viscous flow around the cylinder. There are differences in drag forces from .out files and in postprocessor using force_x@cylinder functions? Can anyone tell why? Even adding viscous forces (given in .out file also) there are still discrepancies in order of up to 7%. Luk |
September 28, 2009, 05:55 |
Rep Power: 16 |
Hi!
I´m also calculating forces over a cylinder and with a monitor point over the surface of the cylinder I obtain a force on 10^7 N while Morrison equation give me 10^5. But I haven´t seen force values in the .out file ?¿ Wich values do you obtain? |
September 28, 2009, 06:05 |
Rep Power: 143 |
I guess because nobody on the forum knows the answer to your question. Have you asked CFX support? The two values should be the same so it sounds like a bug, so CFX support is the only way of doing something about it.
cfxmar's issue seems to simply be of simulation accuracy. Looks like you need to do the normal mesh, timestep and convergence sensitivity. |
September 28, 2009, 06:17 |
Rep Power: 16 |
Thank you ghorrocks,
I have seen that the .out doesn´t give me pressure force values for the pile (a smooth non slip wall), just for the floor (free slip wall). Could it be the problem? |
September 28, 2009, 06:23 |
Rep Power: 16 |
Sorry, It was a mistake. The .out file gives me values for the Pressure Force on walls and Viscous Force on walls in x, y, z axis.
Would Morrison equation Force (the addition of the Inertial and drag forces) be the same as the addition of total Pressure and viscous forces that CFX gives me? |
September 28, 2009, 07:15 |
Lukasz
Rep Power: 17 |
Thanks, for all answer. To Glenn - for me the answer is not very urgent and not that meaningful so I didynt asked him. From my point of view it is rather strange, since there are at least few notices about that at CFX and no one knows
I have noticed that (in POST) "Integral (Pressure x Direction)" gives very close results to (in .out) "Pressure Force" - close but not exact again. Similar (in POST) "Force" gives similar results to (in .out) "Pressure Force"+"Shear Force" - it is very close but not the same. Luk |
September 28, 2009, 16:08 |
Rep Power: 17 |
Hi Luk,
is it 11 or 12? |
September 28, 2009, 16:24 |
Lukasz
Rep Power: 17 |
From forum I see that it occures in various versions.
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
