cavitating calculations on a pressure control valve |
October 12, 2009, 08:03 |
Simon Hastreiter
Rep Power: 16 |
hi guys
right know i´m writing my diploma thesis and for that i make a benchmark between cfx and openfoam. my current subject is a pressure control valve with different lifts and pressure difference. i specified most of it in a nother thread: http://www.cfd-online.com/Forums/ope...rol-valve.html and http://www.cfd-online.com/Forums/ope...lon-model.html . After laminar calculations in both codes i had large differences in my results so i made turbulent simulations for cases with high re-numbers. In the postprocessing appeard negative pressures so i decided to start a twophase calculation. So my problem is the even after more than 1000 iterations in steadystate the force on my moving body dont converge and i have a high imbalance between my massflow on the in- and outlet. what kind of specification would be appropriate in this case or in a transient case. I´m fairly new in cfd and after all my other cases in cfx ran without big problems i dont have too much insight in cfx could there be something i just forgotten. Maybe someone have some clues for me or faced something similar. hope to hear from you mfg simon |
October 12, 2009, 18:20 |
Rep Power: 143 |
http://www.cfd-online.com/Wiki/Ansys...gence_criteria
Cavitation modelling is not an easy topic. Are you sure you need it? It makes things more complicated by orders of magnitude. As it appears you are a beginner then I strongly suggest you get the single phase simulations working reliably before even considering multiphase stuff. I have done plenty of simulations of valves with mild cavitation were a single phase simulation was close enough to get the device performance. If the cavitation region is small then it can be ignored. |
Pressure enigma. | Sara | Main CFD Forum | 22 | July 30, 2009 04:46 |
Pressure Rise Error | emueller | CFX | 0 | May 5, 2009 11:08 |
maintaining a logarithmic velocity distribution | Morten Andersen | CFX | 1 | January 8, 2007 11:37 |
SST in 2D? | Jesper Sørensen | CFX | 16 | December 23, 2006 08:40 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
