May 20, 2011, 14:08 |
Swirl BC problem
Stephen
Rep Power: 16 |
I am trying to set a inlet BC by creating two expressions, one for axial velocity and the other for tangential velocity. The radial velocity is zero. The inlet flow has a swirl of 1. The domain it injects into is set as stationary, but the walls adjacent to the inlet is rotating. The axial expression is set as Vax=(mass flow)(swirl)/(density)(Area) and Vtan=(swirl)(pi)(wheelspeed)/30sec. The issue is that when I start CFX it crashes right away with respect to the lower limit exceeded for static enthalpy and a fatal bounds error detected on variable density. Then it shows an Error #001100279 occured in the subroutine ENFORCE_BOUNDS. I was able to create a ramp function and bumped the timestep down and it ran, but I began to get the same static enthalpy limits and a warning with high Mach number. I believe the way I have the BC setup is incorrect. Does anyone out there have any suggestions? The result file I got back had very high circumferential velocities and negative axial velocities. CFX usually creates walls at inlets if there is reversed flow, but it it not do so.
Display Modes | |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 10 | February 7, 2024 21:50 |
conduction problem | venkataramana | OpenFOAM | 3 | December 1, 2013 07:30 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Swirl in backflow on pressure outlets | Jonas Larsson | FLUENT | 17 | February 3, 2000 02:14 |
