-   -   pressure drop, laminar, use of prism? (http://www.cfd-online.com/Forums/cfx/70007-pressure-drop-laminar-use-prism.html)
galap November 11, 2009 13:09
Hi community,
I'm confused by some results calculated with Ansys CFX. I meshed a 3D structure (air flows through) with tetras and calculate the pressure drop at several inlet normal speeds. So far, results fits quite well to practical measurement data. Now I repeat these calculations with an additional prism mesh (4 layers, tetra settings remaining equal) for a better velocity resolution on surfaces. Though I get pressure drop values, increasing for instance from 600mbar/m to 900mbar/m. Quite a difference and none relation to practical measurements!
I don't know to handle that. The flow is laminar, help manual says prism mesh captures boundary layer physics. Maybe prism should only be used when I have turbulent flows..? Im confused, better solution on surfaces should give me more realistic results, isn't it..
ghorrocks November 11, 2009 22:16
Laminar flows have boundary layers too. If you have thin laminar boundary layers then a prism mesh is still a good idea.
If when you change the mesh your results change a lot then it sounds like you are a long way from a mesh converged solution. You probably need a much finer grid.
galap November 12, 2009 04:50
Thanks, thats a good point. My residuals were set to 10-4 and prism quality aren't good.. I refine my mesh and check results.
