which is correct
Old   February 7, 2012, 06:11
Default which is correct
albert
pato is on a distinguished road
Hi!
i´m have some problems to set up the proper permability and resistance loss coefficient of my porous media. Actually i found different answers about how these coefficient are expressed, having different solutions with both of them.
one is:
You have to input a POROSITY, PERMEABILITY COEFFICIENT and RESISTANCE LOSS COEFFICIENT.
The porosity is simply the % VOID of the region.
The Permeability Coeff governs low speed viscous losses. If Erguns equation is to be adopted, this term can be calculated as:
Kperm = [(Dp^2)*(epsilon^3)*(S^2)]/[150*(1-epsilon)^2]
where:
Dp = equivalent spherical diameter of particle
= 6*(Volume of Particle/Surface Area of Particle)
S = sphrecity (measure of how spherical) = ((pi^1/3)*(6Vp)^2/3)/Ap
The Resistance Loss term governs inertia effects and can be calculated as:
KLoss = 2[1.75*(1-epsilon)/(S*Dp*(epsilon^3)]
and the other is an aproximation which says:
Res.Loss COeff= 2*(0.55/k^0.5)* porosity^2
where 0.55/k^0.5 = form coefficient
both ways have as a result very different values of Kperm and Kloss.
could someone help me? has each Kpermeability necesarily an associated and unique Rloss?
thank you
pato is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Is this understanding of turbulence models correct? 3kha Main CFD Forum 3 January 31, 2011 21:31
Correct location for inflow and outflow boundaries Varun CFX 1 May 23, 2008 03:43
LES correct function luiz eduardo OpenFOAM Running, Solving & CFD 6 September 14, 2007 04:10
Correct lift but wrong pressure drag - possible? zx Main CFD Forum 4 July 27, 2007 23:38
