December 2, 2009, 13:41 |
Problem with the FORTRAN compiler
Eduardo
Rep Power: 16 |
Hi I am using CFX 12 in Linux but also I have it in Windows Platform. I wrote a FORTRAN routine that I successfully compile and run together with CFX solve in windows. However when try to do the same in Linux it does not work. Actually the problem is at the compiling step. When I run from the OS linux window the following line:
Cfx5mkext myroutine.F It shows the following error message: “The compiler command “pgf95” or “ifort” or “gfortran” or “g77” could not be found. Please ensure that the compiler is on your path I have check and I have installed the intelfortran and gccfortran on my machine. My cfx5mkext file is on a directory and the fortran compilers are in others. Could this be the reason? Could anyone give a help? Regards, Eduardo |
December 2, 2009, 15:01 |
#2 | |
Jack
Rep Power: 16 |
http://www.cfd-online.com/Forums/cfx...-compiler.html
December 2, 2009, 16:28 |
Rep Power: 17 |
Did you start ifortvars before compiling?
cfx 12, fortran, linux |
Intel Fortran Compiler & Tutorial 17 | Young | CFX | 1 | March 30, 2011 01:39 |
Fortran compiler problem | Luke | Siemens | 2 | September 18, 2008 03:43 |
CFX and Fortran Compiler Integration | Rob | CFX | 2 | April 26, 2007 00:46 |
Fortran compiler | Arnab | Siemens | 5 | September 14, 2004 03:59 |
problems with intel fortran compiler | ryoga | Main CFD Forum | 3 | September 24, 2003 11:42 |
