Parallel Trouble: CFX 11 XP64 - Help?
Old   November 20, 2009, 10:53
Default Parallel Trouble: CFX 11 XP64 - Help?
Bayard Morales
bbmorales is on a distinguished road
Hi everyone.
I´ve been trying to run CFX 11 in this configuration:
- Intel i5 570
- Windows XP 64bits
In the beggining, the solver just gave the "no partitioner found" or something like this.
Then, I replaced the x86info.exe for a newer (like, 1 year ago) file I had. Then, this message was gone.
Althought, the solver, when it start to run parallel - both MPICH2 and PVM - it give me a 255 error, no matter what I do.
Serial runs fine.
Does anyone had something like it? Any help?
Thanks in advance.
bbmorales is offline   Reply With Quote
Old   November 21, 2009, 05:10
This is a known bug in V11 where it cannot recognise recent CPUs and therefore does not know what solver to use and bombs out with the error you report. There is a fix available (talk to your support person to get it) which allows it to run on more recent CPUs but the i5 chips are very recent and I suspect the fix has not been applied to these chips. Time to upgrade to V12 I think, this will work on the latest CPUs.
Old   December 4, 2009, 10:34
Bayard Morales
Hi, thanks for your help.
I´ve updated to v12, Win XP64, but I´m having some issues.
1) MPICH2 doesn´t works. MPICH.
2) Sometimes, seems that the processor mishandles the processes priorities and then, if i´m running a 4 partition problem, CFX "forgets" to run some of them. Then, the CPU usage is like 100%, 0%, 100%, 0% and the run doesn´t work.
Do you know any solution or tip for these problems?
Thanks
Old   December 5, 2009, 04:59
Make sure you are not using hyperthreading. CFX does not work well on hyperthreading.
The solver should not "forget" to run processes. If it is not hyperthreading stuffing things up it could be that you have run out of memory, partitioning problems or you could be running a fancy-pants physics model which does not parallelise well (eg monte carlo radiation)
cfx 11 64, error, parallel
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 22:51
PhD using CFX Rui CFX 9 May 28, 2007 05:59
CFX 10 VS CFX 11 for combustion Jonathan Lemay CFX 2 May 9, 2007 11:58
Parallel interfom trouble in execution mer OpenFOAM Running, Solving & CFD 6 October 18, 2005 05:45
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
