-   CFX (
-   -   Imbalance in transient simulation (
Roland R December 8, 2009 10:50
While the calculation is running, I always check the mass/energy imbalance and the mass flow at the inlet/outlet.
In steady state simulation there is not problem with these, but I don't understand what does the mass imbalance mean in the case of transient simulation. End of every timestep the imbalance is under 0.1% but the mass flow at inlet and outlet are different (for example 0.3kg/s @inflow and 0.35 kg/s @outflow).
How is this possible?
Attesz December 8, 2009 12:05
Hát ez tényleg elég érdekes, kíváncsi vagyok:D
ghorrocks December 8, 2009 17:55
Assuming your imbalances are small, in a transient simulation it means your modelled domain is loosing mass. This can only happen in a compressible simulation. If it is happening in a incompressible simulation then you have a problem.
Roland R December 9, 2009 06:39
I thought so:)
Thank you;
Roland R.
