Cannot decide value of yplus
Old   October 21, 2011, 09:30
Default Cannot decide value of yplus
td2e09 is on a distinguished road
Good afternoon. I have done a lot of reading on yplus, and am aware of its calculations and why it is important. However I have not been able to see from literature how it is possible to determine what is the yplus value required for any given flow problem, so that the mesh can be constructed accordingly.
Does anyone have any idea how I can examine my flow problem and determine what value of yplus is required, so that I can adjust my mesh accordingly. Or does anyone know any good literature or references on choosing an appropriate value for yplus. Thanks and best wishes.
td2e09 is offline   Reply With Quote
Old   October 22, 2011, 02:18
Mauricio Labarca
mauricio is on a distinguished road
I also had this question sometime ago and i believe it was glenn h. who told this depends a bit on your turbulence model. In my case i wanted to use k-w which needs a very small (close to 1) yplus when i could have used the more advanced (and recomendded by the ansys documentation) SST. I'd also love to find any papers on this subject as well. If you can't find anything and you'd like to ensure the best yplus,
why don't you add it as a parameter for a sensibility analysis? make a mesh with some settings, run a simple converging simulation and write down results, change the yplus, see how the results change, and go on until the results are not depending on your mesh, or you start getting limited by your own computational resources.
mauricio is offline   Reply With Quote
Old   October 22, 2011, 05:58
The answer is all over this forum, and in the FAQs as well - see http://www.cfd-online.com/Wiki/Ansys...publishable.3F
The answer is a sensitivity analysis. Different flows have different sensitivities to the boundary layer, so of course their requirements for BL meshing is different. That is why there is a not a universal answer.
Old   October 25, 2011, 09:20
Thats great, many thanks to you both for your help
Old   October 27, 2011, 09:03
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by ghorrocks View Post
the answer is a sensitivity analysis. Different flows have different sensitivities to the boundary layer, so of course their requirements for bl meshing is different. That is why there is a not a universal answer.
Let say If we are analyzing the flow over airfoil for following flow regimes (Reynolds number is sufficiently high so that the flow can be assumed fully turbulent)
1. subsonic
2. transonic
3. supersonic
can we set yplus for the different airfoils based on above study or again we have to make the sensitivity study for each new configuration?
Far is offline   Reply With Quote
Old   October 27, 2011, 16:48
I would check this with a simple sensitivity test, but I reckon you will find you are pretty insensitive. As long as your y+>11 and is smallish then it should be fine.
Edit: Oh, except for all the exceptions - separated flow, heat transfer, multiphase etc etc
How to calculate Y+( Yplus) mohammad Main CFD Forum 3 January 11, 2011 23:23
which yplus (SST) sanchezz CFX 17 January 11, 2010 04:45
Who stole my Yplus? Chebeba CFX 4 March 23, 2006 04:18
X-Y plot of Yplus in Fluent 5.3 Luo FLUENT 24 April 11, 2000 06:07
heat transfer coefficients with "bad" yplus Andrew Main CFD Forum 4 April 8, 1999 04:43
