make inlet outlet
Old   December 22, 2009, 00:29
Default make inlet outlet
eren
eren is on a distinguished road
hello all,
I 'm new in cfd,...
in manual help ansys cfx with sample static_mixer mesh.gtm, how to make inlet and outlet because when catia design (static_mixer) import to cfx inlet and outlet there is nothing?
thankyou so much all...
eren is offline   Reply With Quote
Old   December 23, 2009, 06:42
Roland Rakos
Roland R is on a distinguished road
I don't understand your question, I try to help you...
1.step
define a geometry (in Catia, ProE, DesingModeler etc.)
2.step
Mesh generate (for example: with ICEM CFD or CFX Mesher)
Here you can define the part names (inlet, outlet, walls etc.)
Finally export the mesh to CFX
3.step
Import the mesh file to CFX. If you have defined the part names properly, than these will appear in CFX.
Finally based on the part names you can defined the boundary conditions...
Regards
Roland
Roland R is offline   Reply With Quote
Old   January 5, 2010, 01:27
eren
1.step
2.step
3.step
Regards
Roland
yes!!! thanks so much Rolland
make inlet outlet
Passing Average Temp from Outlet to Inlet Steve Scotts FLUENT 1 August 27, 2008 05:02
mean velocity change from inlet to outlet ro FLUENT 2 April 19, 2008 13:37
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 02:36
recirc tank, inlet outlet conditions david CFX 1 May 22, 2007 03:23
Inlet & Outlet Boundary Conditions dhananjay Main CFD Forum 2 December 21, 2006 10:03
