Export results data
Old   December 21, 2009, 03:23
Default Export results data
ealatawi is on a distinguished road
hi
I need to export results data (velocity, kinetic energy and dissipation..etc)from CFX results file in order to post-process using fortran, to do that I have to know the block connectivity and the number of blocks used in constructing the computational domain (using ICEM).
does any body know how to get information about block number and how are they connected.
thanks
ealatawi is offline   Reply With Quote
Old   December 21, 2009, 13:19
Abou ali is on a distinguished road
In the CFX result file there was no information about blocks and their connectivity according to my experience!!!!.
Abou ali is offline   Reply With Quote
Old   December 29, 2009, 18:04
kingjewel1 is on a distinguished road
What do you mean by blocks? Cell count? If so CFX post will give you cell count in the function calculator (Count>Domain). Does this help?
kingjewel1 is offline   Reply With Quote
Old   December 31, 2009, 07:32
Default About Blocks
kingjewel1: Thanks for reply
My geometry is created (in ICEM) using structured multi-block mesh (hexahedral elements). In order to use the solution data i need to export the CFX results file. Hence, in order to get the data for each node i need to find out the block number (including their dimensions, i.e., each block has number of nodes along I, J and K) and how these blocks are connected. Unfortunatly, i did not find out anything in CFX manual about the block number and block connectivity.
Any suggestions...
Old   January 5, 2010, 23:06
Rikio
rikio is on a distinguished road
Send a message via Skype™ to rikio
It seems CGNS could provide the information you need. Export the results into a CGNS file for FORTRAN.
I am not sure, just for your reference.
rikio is offline   Reply With Quote
Old   January 6, 2010, 14:27
stumpy is on a distinguished road
CFX is an unstructured code. There are no i,j,k numbers or block information, regardless of where your mesh came from, there are only node numbers.
stumpy is offline   Reply With Quote
how to export geometric data into tecplot anne CFX 1 September 29, 2008 21:45
Export CFD Solver results to text file format Maik Main CFD Forum 2 May 23, 2008 01:34
macro for data automatic export Andrea CFX 0 May 9, 2008 08:09
batch process- export data Grace FLUENT 0 May 15, 2006 20:14
How to export data Nareerat FLUENT 1 April 8, 2004 05:26
