-   -   CFX not compatible with Window 7 & how to generate table (http://www.cfd-online.com/Forums/cfx/71522-cfx-not-compatible-window-7-how-generate-table.html)
mechovator January 6, 2010 05:19
Hello dear
1. I have installed Window 7 and CFX is not working with it. Means its not compatible. So if any one know the solution to the problem pls do tell me.
2. I want to generate table of absolute pressure varying in the Y direction (the depth of the reservoir) in a reservoir in CFX post. I went through tutorial in which table was created in post processing but was not able to understand it completely. So pls if any of you are aware of the method pls write in numbered bullet form.
Regards
Mechovator
Attesz January 6, 2010 07:59
I'm using v11 on win7 x64, and its working fine. I get some problems with licensing, when i've installed the new antivirus software, the new firewall was too "strong". Check the firewall!
ckleanth January 6, 2010 16:54
http://www.ansys.com/services/ss-platform-support.asp
kingjewel1 January 7, 2010 09:15
Originally Posted by mechovator (Post 241609)
Hello dear
Regards
Mechovator
Version 11 32bit works fine on windows 7 31bit. The problem you're experiencing no doubt is that you're trying to use a 32bit CFX on 64bit windows, which doesn't work.
mechovator January 13, 2010 07:11
Please also reply to the second query
kingjewel1 January 14, 2010 07:51
I don't know the method of which you speak per say. However by creating various lines along a constant X axis. ie. Location>line. Samples >100
you can plot the chart (making a new chart line for each line) using these. perhaps more fiddly but does the same.
