CFX not compatible with Window 7 & how to generate table
Old   January 6, 2010, 04:19
Default CFX not compatible with Window 7 & how to generate table
mechovator
mechovator is on a distinguished road
Hello dear
1. I have installed Window 7 and CFX is not working with it. Means its not compatible. So if any one know the solution to the problem pls do tell me.
2. I want to generate table of absolute pressure varying in the Y direction (the depth of the reservoir) in a reservoir in CFX post. I went through tutorial in which table was created in post processing but was not able to understand it completely. So pls if any of you are aware of the method pls write in numbered bullet form.
Regards
Mechovator
mechovator is offline   Reply With Quote
Old   January 6, 2010, 06:59
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
I'm using v11 on win7 x64, and its working fine. I get some problems with licensing, when i've installed the new antivirus software, the new firewall was too "strong". Check the firewall!
Attesz is offline   Reply With Quote
Old   January 6, 2010, 15:54
ckleanth's Avatar
George
ckleanth is on a distinguished road
http://www.ansys.com/services/ss-platform-support.asp
Top 4 tips
1. Knowledge is everything and Ignorance is dangerous.
2. Understand your limitations and try to eliminate them.
3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window.
4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials
ckleanth is offline   Reply With Quote
Old   January 7, 2010, 08:15
kingjewel1 is on a distinguished road
Originally Posted by mechovator View Post
Hello dear
Regards
Mechovator
Version 11 32bit works fine on windows 7 31bit. The problem you're experiencing no doubt is that you're trying to use a 32bit CFX on 64bit windows, which doesn't work.
kingjewel1 is offline   Reply With Quote
Old   January 13, 2010, 06:11
Default Please also reply to the second query
mechovator
Old   January 14, 2010, 06:51
I don't know the method of which you speak per say. However by creating various lines along a constant X axis. ie. Location>line. Samples >100
you can plot the chart (making a new chart line for each line) using these. perhaps more fiddly but does the same.
compatible, generate table, window 7
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
Is Ansys compatible with Window Vista? If yes then NITIN DEWANGAN CFX 2 July 13, 2008 18:18
CFX Post Table Generation Claudia CFX 1 July 25, 2006 07:32
Can CFX Automatically generate hybrid meshes? JJ CFX 0 August 28, 2003 21:18
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
