January 2, 2010, 04:24 |
Opening velocity varies over time?
Rep Power: 17 |
Hi there,
How could I make an opening velocity vary over time. Eg someone breathing? We assume the frequency of respiration under light physical work is 17 times per minute with a time-mean rate about 8.4 l/min How to implement in CEL? Thank you |
January 2, 2010, 05:24 |
Rep Power: 16 |
First try to find a mathematical formulation of the velocity or the mass flowrat versus time. I mean velocity=f(t) were f is a periodic function with a period T=60/17 And f(0s)=0m/s f(T)=0m/s Finally: area/T*Integral[(velocity) between T and 0] =8.4/17 must be verified. |
January 2, 2010, 06:29 |
#3 | |
Rep Power: 17 |
(1) so if f(t+p)=f(t), f(0)=f(T)=0 such a function could be sin(60/17+t). (2) 1/T*Area*[F(T)-F(0)]=8.4/17, where F(t)=integral of f(t) => -cos(60/17+T)+cos(60/17)=8.4T/(17*Area) My question is how to adjust the units so that CFX understands the CEL to be in m/s say instead of radians (from sin)? Thank you and Happy New year |
January 2, 2010, 09:37 |
Rep Power: 16 |
In the first equation you must add Vmax, it be come Vmax*sin() were sin is a dimensionless quantity and Vmax can be calculated from the second equation. |
January 2, 2010, 17:52 |
#5 | |
Rep Power: 17 |
How can you make sin nondimensional as CFX tells me it is be radians? |
January 3, 2010, 11:13 |
Rep Power: 16 |
Can you display the error message sent by CFX here ? |
January 4, 2010, 04:37 |
Rep Power: 17 |
I divided t/[s], now the error message disappears. So I have 1.7[ms^-1]*sin(60/17+t/[s]) and have made this a monitor point as well. However when I run a transient solution I'm given the error
ERROR #004100025 has occurred in subroutine SCL_RESCH. | | Message: | | A floating point overflow has occurred. Check solver | | parameters, boundary conditions and mesh quality. The | | calculation will be terminated. | | Note: if this error occurs at the first iteration, that may | | be caused by the initial guess, e.g., a zero initial | | velocity and zero dynamic viscosity. | |--------------------------------------------------------------------| |
January 4, 2010, 16:08 |
Rep Power: 16 |
It's earlier to speak about the solver error message. The formulation which you found doesn't describe exactly what you want. Try to plot the function in the Plot panel of the Expression window (use t=0s to 60s) and see what it gives. I think that a right function can be: Vmax*sin(2pi*t/T). The integration of this function in a period is 0, this signify that the mass flowrat at inspiration = the mass flowrat at expiration = 8.4/17 l/min then Vmax can be calculated from the following eq: area/T*Integral[(velocity) between T/2 and 0] =8.4/17. Try to verify the new expression again. |
January 4, 2010, 17:24 |
#9 | |
Rep Power: 17 |
sin(2pi*t+60/17). What am I missing? 2)area/T*int(Vmax*Sin(2pi*t/T))dt=8.4/17 between 0 and T/2 => Vmax=8.4e-3/(Pi*17*Area)~0.621[m/s] which seems very reasonable. presuming 8.4 litres is 8.4e-3 meters cubed |
January 12, 2010, 18:37 |
#10 | |
Rep Power: 17 |
January 14, 2010, 06:19 |
#11 |
Rep Power: 16 |
I think that you have used an inlet and outlet boundaries conditions. This is not consistent with this problem because this type of boundaries prevents the flow to change direction. The solution is to use an opening boundary condition in both side of the domain. |
January 14, 2010, 06:39 |
#12 | |
Rep Power: 17 |
Subsequently I tried using an outlet and obtained similar flow rates but biased towards the inhalation (logically). Picture is of the domain for reference purposes. small cube in the middle is cut out. One face is the opening. Set up: Domain temp: 21C Nose opening temp: 34C Fluid:Air Ideal gas Buoyancy: ON Buoyancy Ref density: 1.204kg/m^3 Opening Uvelocity: Vmax*sin(2*pi*t/T/1[s]) By the way thank you for your help. What do you think? |
January 14, 2010, 17:05 |
#13 |
Rep Power: 16 |
I think that there is a problem in the simulation definitions!!!! If you attach the output file here, maybe I can help. |
January 14, 2010, 17:21 |
#14 | ||
Rep Power: 17 |
January 15, 2010, 03:05 |
#15 |
Rep Power: 16 |
I have seen your output file and maybe the problem is in the symmetry condition. I have run a test simulation of a nose (0.05*0.05*0.05 cm3) in a domain of 2*2*2 m3. I use an opening boundary condition in one side of the nose with the same condition as yours, for the boundaries of the domain I set them as opening with 0 Pa. You can see here the rusults. |
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Time Variable Velocity programming? | Michelle | FLUENT | 2 | February 18, 2008 12:38 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
Graph ploting of velocity vs time | Lam | FLUENT | 1 | October 31, 2003 06:50 |
