input method for various temperature value
Old   January 15, 2010, 17:24
Default input method for various temperature value
jai
jaikrishna
jai is on a distinguished road
I've thermal conductivity of steel from 400 to 700 degree C at the interval of 25 degree C.
how can i feed it this valves into CFX?
from 400 to 700 k-valve is not linear...
jai is offline   Reply With Quote
Old   January 15, 2010, 20:52
Tristan Burton
Tristan is on a distinguished road
Create a CEL expression for thermal conductivity as a function of temperature based on your fit to the data (e.g. VarThermConduct=a+bT+cT^2+... where you make sure each of the terms has the correct units) and replace the value for the Thermal Conductivity under the Material Properties tab with your expression (VarThermConduct).
Tristan
Tristan is offline   Reply With Quote
Old   January 15, 2010, 23:07
Or use a 1D interpolation function. This uses linear interpolation between the points.
Old   January 16, 2010, 13:20
jai
jaikrishna
please explain the formula elaborately.
thanks.
Old   January 16, 2010, 15:58
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
you should make an user function, with two points 400 and 700 K, with step number (700-400)/25. After that you should define an expression, which uses this function. And when you set the temperature, you should set this expression by its name. These steps are well described in cfx help. Good luck!
Attesz is offline   Reply With Quote
free stream temperature qzhu FLUENT 5 June 10, 2015 03:55
temperature 1K- 5000K aga FLUENT 5 October 2, 2006 03:02
Static temperature David FLUENT 2 April 1, 2005 10:57
About fix wall temperature in wall boundary joon Siemens 2 March 10, 2003 01:41
Sequential calculation of Temperature and mass tra J.W.Ryu FLUENT 7 June 18, 2002 07:12
