Home > Forums > CFX
due to wall function, continue refining mesh until when
Old   January 16, 2010, 15:50
Default due to wall function, continue refining mesh until when
zandi's Avatar
Fatema Zandi Goharrizi
zandi is on a distinguished road
Hi
I'm doing a free surface flow CFD modeling project that the velocity and pressure near the bottom (wall boundary) are important parameters. for evaluating the pressure result I have data and after refining mesh I saw that the pressur was not sensitive to it and I reached to a good answer.
but for velocity I do not have any data and just want to reach an answer that not depedent on mesh size.
I use k-epsilon standard in CFX code
so my limitation for y+ is 20 and 100 (CFX help)
  • now i'm reaching to y+ under 20 and still my velocity profile near the boundary changes due to make the meshes smaller. what can I do
please help
zandi is offline   Reply With Quote
Old   January 16, 2010, 17:21
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
I would switch to the SST turbulence model then you can use the scalable automatic wall functions. Then it would matter when y+ goes under 11 and you can refine as much as you like.
Is there a reason you wish to use k-e?
Old   January 17, 2010, 07:59
zandi's Avatar
Dear G. Horrocks Salam
and thanks a lot
actually my masters insist on it maybe they're not so friendly with low Rey models. I'm not too!
they said the k-e is sufficient for my case.
by the way
  • if I change my turbulent model how much change result in my work. does my pressure or mass flow rate change. do I have compute any parameters before
best regards Zandi
Old   January 17, 2010, 17:20
SST is not a low Reynolds number turbulence model! It is a general purpose turbulence model and works well for a wider range of flows than k-e. If you are having problems with mesh refinement in k-e then I recommend you go to SST as the wall function issue is not a problem for SST.
As for whether the change in turbulence model will affect things - how can I possibly know that? You have not described at all what you are doing. It is straightforward to work that out for yourself - do a test run using SST and find out for yourself whether it makes a difference. For most flows it takes the same run time as k-e and converges the same so it should be a easy test to do.
Old   January 18, 2010, 03:53
zandi's Avatar
thank you very much from your advice
Old   January 18, 2010, 10:16
Paulo Alexandre Costa Rocha
paulo is on a distinguished road
Originally Posted by ghorrocks View Post
(...) For most flows it takes the same run time as k-e and converges the same so it should be a easy test to do.
it can be even faster, if you use the k-epsilon results to start your simulation.
Best Regards,
Paulo Rocha
paulo is offline   Reply With Quote
Old   January 18, 2010, 14:29
zandi's Avatar
Best Regards,
Paulo Rocha
thank you friend but could you tell me how I could use the result
maybe when we want write the solver but I don't know which option should I use
thanks again
Old   January 18, 2010, 17:47
Why use k-e at all? Just use SST then you don't have any issues about wall functions with mesh refinement. The SST model has superseded the k-e model for most general applications.
Old   January 23, 2010, 05:16
zandi's Avatar
thank you, nice of you
independent result, k-epsilon, refining mesh, yplus
Thread Tools
Trackbacks are On
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
BlockMesh FOAM warning gaottino OpenFOAM Native Meshers: blockMesh 7 July 19, 2010 14:11
OpenFoam 14 installation problem gfcoppola OpenFOAM Installation 20 November 2, 2007 14:38
Wall function problem in Fluent mefpz FLUENT 1 October 10, 2007 13:43
3-D turbulence model with wall function Henry Main CFD Forum 7 May 19, 2006 10:40
