using ANSYS workbench to model fluid flow in a porous structure
Hi all,
I am trying to model the diffusion of oxygen dissolved in water through a porous medium, the medium has channels cut through it as well. my problem is that my O2 concentration is uniform throughout the transient timesteps. whereas what should be happening is a higher concentration closer to the channels and less further away. can ANSYS automatically do this or do I have to specify a flow between the fluid and porous domains? also, is a diffusion simulation realistic using only the permeability and resistance loss parameters? would very much appreciate any help. thanks. |
| All times are GMT -4. The time now is 16:02. |
