-   -   Airflow in a chamber (http://www.cfd-online.com/Forums/cfx/72156-airflow-chamber.html)
Issa January 27, 2010 09:57
Please be informed that I'm using CFX to simulate airflow in a chamber. The chamber is ventilated by displacement ventilation with air velocity of 0.1 m/s and there are some heat sources in the chamber. When i used steady state simulation, i didn't get a converged solution because the flow is mainly buoyancy driven flow. So, I decided to go for transient simulation. But my question is what is the appropriate time step and total time should I use for transient simulation? Thank you
Regards,
Issa
Issa January 27, 2010 14:53
Still waiting for a reply. Kindly, I need your help
Regards,
Issa
ghorrocks January 27, 2010 16:46
Time step size selection is discussed in the documentation. In summary you want to have 3-5 coefficient loops per time step. You can use an adaptive time step technique to find this quickly if you like.
Have you tried the tips here to get convergence in steady state?
http://www.cfd-online.com/Wiki/Ansys...gence_criteria
But I suspect you are right in that the result is transient which means you only real approach is a transient model. HVAC flows, especially ones with heat sources tend to have large scale transient behaviour.
Issa January 27, 2010 17:02
Hi ghorrocks,
Thank you for your reply. Regarding the documentation, where i can find it? Thank you.
Regards,
Issa
Issa January 28, 2010 03:48
Hi ghorrocks,
Thank you for your reply. Kindly, where i can find the documentation? I would like to know what is the required time step and the total time for transient simulation. Thank you.
Regards,
Issa
Attesz January 28, 2010 08:37
In CFX help!
kingjewel1 January 30, 2010 10:27
Originally Posted by Issa (Post 244017)
Hi ghorrocks,
Regards,
Issa
You can set your timestep based on the air residence time within your room. Typically your Courant number should not be greater than 20.
Personally I run the simulations for a few thousand iteration on a Timescale factor of 5 then switch to physical.
Issa January 30, 2010 11:12
Dear kingjewel1,
Thank you for your reply. Kindly be informed that I'm using transient simulation not steady state. For steady state i tried physical timescale but the solution didn't converged. Actually for my case the flow is buoyancy driven flow. So, it is too difficult to get converged solution using steady state simulation. For transient simulation I would like to know what is the appropriate time step and the total time for the simulation. Actually I don't know what is the residence time? So what to do?
Regards,
Issa
ghorrocks January 30, 2010 16:43
I have already told you how to set time step in a transient simulation.
The total time for the simulation is problem dependent. It probably has a large scale transient structure so you will want a few oscillations of this structure so you can get a reasonable overall picture.
Kingjewel - most CFX steady state simulations converge with 100-200 iterations. So why are you running thousands? Is your physics complicated?
kingjewel1 January 30, 2010 17:10
Sorry I did actually mean hundreds. Thanks for the correction.
