January 27, 2010, 08:57 |
Airflow in a chamber
Rep Power: 16 |
Please be informed that I'm using CFX to simulate airflow in a chamber. The chamber is ventilated by displacement ventilation with air velocity of 0.1 m/s and there are some heat sources in the chamber. When i used steady state simulation, i didn't get a converged solution because the flow is mainly buoyancy driven flow. So, I decided to go for transient simulation. But my question is what is the appropriate time step and total time should I use for transient simulation? Thank you Regards, Issa |
January 27, 2010, 13:53 |
Rep Power: 16 |
Still waiting for a reply. Kindly, I need your help Regards, Issa |
January 27, 2010, 15:46 |
Rep Power: 143 |
Time step size selection is discussed in the documentation. In summary you want to have 3-5 coefficient loops per time step. You can use an adaptive time step technique to find this quickly if you like.
Have you tried the tips here to get convergence in steady state? http://www.cfd-online.com/Wiki/Ansys...gence_criteria But I suspect you are right in that the result is transient which means you only real approach is a transient model. HVAC flows, especially ones with heat sources tend to have large scale transient behaviour. |
January 28, 2010, 07:37 |
Attesz
Rep Power: 17 |
In CFX help!
January 30, 2010, 09:27 |
#7 | |
Rep Power: 17 |
Personally I run the simulations for a few thousand iteration on a Timescale factor of 5 then switch to physical. |
January 30, 2010, 10:12 |
Rep Power: 16 |
Dear kingjewel1,
Thank you for your reply. Kindly be informed that I'm using transient simulation not steady state. For steady state i tried physical timescale but the solution didn't converged. Actually for my case the flow is buoyancy driven flow. So, it is too difficult to get converged solution using steady state simulation. For transient simulation I would like to know what is the appropriate time step and the total time for the simulation. Actually I don't know what is the residence time? So what to do? Regards, Issa |
January 30, 2010, 15:43 |
#9 | ||
Rep Power: 143 |
I have already told you how to set time step in a transient simulation.
January 30, 2010, 16:10 |
#10 | |
Rep Power: 17 |
Display Modes | |
[GAMBIT] Dynamic Meshing of a combustion chamber | donarundas | ANSYS Meshing & Geometry | 1 | December 2, 2009 07:13 |
I need design planes of combustion chamber HITACHI GE | AdidaKK | Main CFD Forum | 0 | July 2, 2009 14:04 |
Coal particles in combustion chamber | Luis Filipe Fabiani | CFX | 2 | March 10, 2009 15:37 |
Flow and Heat transfer in a Thawing chamber | B.Prabhu | FLUENT | 0 | May 12, 2002 15:13 |
A moving object within a chamber | Whitaker | FLUENT | 5 | October 10, 2000 22:02 |
