February 4, 2010, 09:03 |
Windows to Linux => END problems...
prout
Hi everyone,
I have a problem with the CFX solver. When I run a case that was defined on a Windows machine on my Linux computer, I get this error: ccl2flow: * command language error * Message: parseCCLLineH: unmatched END Context: returned by cclApi call Knowing that might come from the transfer of the .def file from Windows to Linux, I re-defined my .cfx file and generated the .def on the Linux machine. I thought this would work, but then I got this error: ccl2flow: * command language error * Message: 3 missing END statement(s) in input Context: returned by cclApi call I do not understand...could this come from the fact that in both cases, my mesh was defined on a Windows machine? I did not check every END statement in the .def files because it's quite boring, and adding manually the missing ENDs will be quite annoying if I have to do it for each case I have to compute... I tried changing the boundary conditions, but it did not change anything. Here's some info about the setups: Windows Vista is used and both machines run CFX 12.0. Thanks in advance for your help! |
February 4, 2010, 12:45 |
George
Rep Power: 18 |
the ccl for both windows and linux should be the same
it is more likely that your file is corrupted or the ccl was wrong to start with. best is to make sure it works in windows, export all ccl then you can check it in linux. it shouldnt matter where you want to run the simulation if you already import a mesh in the def file
Top 4 tips 1. Knowledge is everything and Ignorance is dangerous. 2. Understand your limitations and try to eliminate them. 3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window. 4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials |
February 4, 2010, 13:38 |
prout
I just tried to run the same files on both machines, it works in Windows, but not in Linux.
Files have been copied using WinSCP, binary mode. Seems like nothing is corrupted. I might have just found the problem though: my Linux machine is running CFX-12.0.1 build 2009.04.14-22.59, whereas CFX-12.0.1 build 2009.04.14-23.02 is running in Windows...could it be the source of the problem?! That would not explain why a run defined from scratch (but the mesh) on my Linux computer is also erroneous... Thanks. |
February 4, 2010, 16:26 |
Rep Power: 143 |
I would load it into CFX-Pre. That should give you an idea of where the CCL error is. When fixed it will also regenerate the def file and it will probably work fine.
February 4, 2010, 16:53 |
prout
I found where the problem came from. Looks like the installation of the CFX solver on the Linux machine was not done properly: I ran the case which was copied from my Windows laptop on another Linux machine, and everything worked fine. And my machine was not the only one with the problem. In the end I lost more than a day, but I gave some work to do to the tech guys ^^
Thanks for your answers! |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Opening velocity varies over time? | kingjewel1 | CFX | 14 | January 15, 2010 03:05 |
error using combination of step function | xujjun | CFX | 1 | January 15, 2008 16:46 |
Single Bubble | Gerrit Senger | CFX | 4 | March 12, 2007 16:29 |
