uncertain on model outlet definition
Old   February 10, 2010, 02:03
Default uncertain on model outlet definition
mactech001 is on a distinguished road
Dear all,
i've done some tests on a housing with an inlet and an outlet. on both the inlet and outlet side, i've valves which i use to influence the pressure of the inlet and outlet, and flowrate at the inlet.
data i have is: inlet pressure is 14.6kPa, outlet pressure is 4.8kPa and inlet flowrate is 12L/min.
i would like to use CFX to estimate the pressure for me, in order to gain more confidence on my calculations. i'll define input flowrate of 12L/min. am i correct to define the outlet of the housing model with the following:
1) Boundary type: Outlet
2) Static Pressure = 4.8kPa
please??
or should i use Average Static Pressure using the Average over Whole Outlet option?
Please comment. thanks!
Thank you for your kind attention.
Kind regards,
mactech001
Currently using: ANSYS v13
mactech001 is offline   Reply With Quote
simple model, difficult outlet Eric CFX 7 May 23, 2014 08:13
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 19:23
using outlet conditions as inlets for other model George Siemens 1 February 1, 2002 05:27
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
