Obtaining Coefficient of Lift and Drag
Old   February 12, 2010, 12:14
Default Obtaining Coefficient of Lift and Drag
Atella is on a distinguished road
I am investigating the performance of an aircraft wing and I need to find out the Coefficients of Lift and Drag for the wing.
I am able to run a simulation and obtain the contour and vector plots but I am unable to find if there is a part to CFX which will give me a value for the Cl of Cd.
If anyone would know how i could get this out it would be much appreciated.
Thanks
Atella is offline   Reply With Quote
Old   February 13, 2010, 06:01
I must have answered this question a dozen times. I really should write a wiki on it....
Extract the forces off the airfoil either from the output file or from CFD-Post. Then stick the other values in (density, free stream velocity) and use the definition of CD and CL to get the lift and drag coefficients.
If you want to you can write a CEL expression to calculate this as the simulation progresses, Then you can output it to a monitor point and then you can use CL and CD to help inform your decision as to whether the simulation has converged.
lift & drag coefficient on airfoil n. natik FLUENT 8 March 31, 2015 19:02
Fluent Good Lift coefficient BAD drag coefficient Rif Main CFD Forum 4 March 9, 2010 10:52
Drag coefficient & Lift coefficient?? mehrdadeng CFX 15 December 9, 2009 21:49
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
drag and lift coefficient Noé Siemens 5 July 13, 2004 10:21
