February 21, 2010, 08:43 |
Ansyslmd.exe process goes to 100% using VPN
Luis Filipe Fabiani
Hello
I have the Ansys CFX package 12.1 installed on my laptop to view the results, setup cases, etc. When I connect to our office network through a VPN connection, the ansyslmd.exe process goes to full throttle (50% CPU usage) and stays that way untill I restart the computer. When I fisically connect to our network (cable), this behavior does not occur, only with VPN connection. Has anyone noticed something similar? Thanks |
February 21, 2010, 19:02 |
Rep Power: 143 |
My guess is the screen display is having problems over the VPN. These can be tricky problems to fix. You will have to do lots of digging to find the answer on that one.
May 24, 2011, 10:49 |
Arslan
Hi;
I have the same problem. Have you find any solution? Please share... Best regards... |
August 9, 2012, 00:21 |
reza
Dear all,
I had the same problem several month ago but I found a way to solve it. 1-by pressing "ctrl+shift+Esc" window task manager will open 2-click on "performance" tab 3-click on "resource monitor" button then the resource monitor window will open 4-in "overview" tab find "ansyslmd.exe" and check the box on its left 5- then R-click on "ansyslmd.exe" and click on suspend process note: when you want to use "Ansys" softwer you should do the same but select the "resume process". after each restart or turning off "ansyslmd.exe" will be active again. Have fun |
ansyslmd vpn |
Error: Fluent process could not be started | Clem | FLUENT | 1 | November 26, 2015 14:23 |
dxFoamExec orphan process | bigphil | OpenFOAM Post-Processing | 0 | March 19, 2009 12:08 |
Fluent coupled with external process | Nitesh Goyal | FLUENT | 0 | July 10, 2007 10:35 |
how to simulate evaporating process of refrigerant | chingyou | FLUENT | 0 | October 25, 2005 22:41 |
controling fluent process | Madhukar Rapaka | FLUENT | 2 | October 13, 2005 10:52 |
