Calculation keep using swap file
Old   February 23, 2010, 03:37
Default Calculation keep using swap file
pad
PA
pad is on a distinguished road
Hello all,
Short description of my problem. I have a case running in parallel on a Linux cluster - 8 nodes w/ 2 Gb memory on each node. The case has approx. 3.3 million tets.
When running the case on the nodes only about 1.0-1.4 Gb is used on each node and a swap memory of 180-250Mb is created - one node only uses 30Mb though. Does anybody have an idea as to why the nodes are not using the full potential of the available memory? There is no other processes running on the nodes.
I suspect the swap to be the reason for my long calculation times.
I have started the simulation from the command line using the -s option for increased memory estimation.
Regards,
Per
pad is offline   Reply With Quote
tecio compilation errors in latest 1.6.x rsamuel OpenFOAM Bugs 2 June 25, 2021 08:10
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
